跳转到主内容
Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement
你所需要的
  1. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Disconnect the hose: 步骤 1 中的图像 1,2 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Disconnect the hose: 步骤 1 中的图像 2,2
    • Make sure the carpet cleaner is turned off and completely disconnected from power.
    • Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
  2. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Remove the bottom cover: 步骤 2 中的图像 1,1
    • Use a 3 mm hex key to remove two bolts securing the bottom cover.
  3. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 3 中的图像 1,3 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 3 中的图像 2,3 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 3 中的图像 3,3
    • Rotate the bottom cover down toward the bottom of the carpet cleaner, then pull it straight back toward the rear of the carpet cleaner to remove it.
    • Don't completely remove the cover yet. There is a ground wire connecting the cover to the carpet cleaner that must be disconnected first.
  4. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Disconnect the ground wire: 步骤 4 中的图像 1,1
    • Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
  5. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Remove the pump cover: 步骤 5 中的图像 1,1
    • Use a 3 mm hex key to remove the four bolts securing the pump cover.
  6. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 6 中的图像 1,2 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 6 中的图像 2,2
    • Remove the pump cover.
  7. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Remove the vacuum motor assembly: 步骤 7 中的图像 1,1
    • Use a flathead screwdriver to loosen the hose clamp securing the flexible hose to the vacuum motor.
  8. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 8 中的图像 1,1
    • Use a 3 mm hex key to remove the two bolts securing the vacuum motor cover.
  9. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 9 中的图像 1,1
    • Pull the flexible hose straight off of the vacuum motor to remove it.
  10. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 10 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the three screws securing the vacuum motor cover to the vacuum motor.
  11. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 11 中的图像 1,1
    • Remove the vacuum motor cover.
  12. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Remove the fan cover: 步骤 12 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the two screws securing the fan cover.
  13. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 13 中的图像 1,2 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 13 中的图像 2,2
    • Remove the fan cover from the vacuum motor.
  14. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Disconnect the vacuum motor: 步骤 14 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the screw securing the ground wire to the vacuum motor.
  15. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 15 中的图像 1,1
    • Use a pair of flush cutters to cut all the zip-ties securing any wires to the vacuum motor.
  16. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 16 中的图像 1,3 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 16 中的图像 2,3 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 16 中的图像 3,3
    • Use a pick or small flathead screwdriver to push down on the tab securing one of the motor's power cable connectors while gently sliding the connector out of its slot.
    • Do not completely remove the spade connector yet. The contact underneath it is tensioned by a spring and will fly out if you completely remove the spade connector.
  17. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 17 中的图像 1,3 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 17 中的图像 2,3 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 17 中的图像 3,3
    • Use a zip tie, or anything flat and roughly the size of the spade connector, to slide into the slot as you slide the spade connector out of the slot.
    • Make sure the zip tie holds the spring contact down before you remove the spade connector.
    • Your new motor may come with power cables already installed. If so, repeat the last three steps with the new motor to remove its power cables.
    • Leave the zip ties in the new motor until you're ready to plug in the spade connectors.
  18. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 18 中的图像 1,2 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 18 中的图像 2,2
    • Repeat the last two steps to remove the other power cable on the vacuum motor.
    • Use the photos in this step as a reference for correctly reinstalling the cables on the new motor.
  19. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: 步骤 19 中的图像 1,1
    • Your new vacuum motor may not come with a vibration damping pad already installed. If so, carefully peel the pad off the old motor and transfer it to the new motor.
结论
Adam O'Camb
于04/11/15注册
196,701 声望
创作了416篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 764
