跳转到主内容
Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement
你所需要的
  1. Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement, Disconnect the hose: 步骤 1 中的图像 1,2 Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement, Disconnect the hose: 步骤 1 中的图像 2,2
    • Make sure the carpet cleaner is turned off and completely disconnected from power.
    • Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
  2. Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement, Remove the bottom cover: 步骤 2 中的图像 1,1
    • Use a 3 mm hex key to remove two bolts securing the bottom cover.
  3. Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement: 步骤 3 中的图像 1,3 Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement: 步骤 3 中的图像 2,3 Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement: 步骤 3 中的图像 3,3
    • Rotate the bottom cover down toward the bottom of the carpet cleaner, then pull it straight back toward the rear of the carpet cleaner to remove it.
    • Don't completely remove the cover yet. There is a ground wire connecting the cover to the carpet cleaner that must be disconnected first.
  4. Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement, Disconnect the ground wire: 步骤 4 中的图像 1,1
    • Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
结论
2等其他人完成本指南。
Adam O'Camb
于04/11/15注册
196,940 声望
创作了416篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 468
