简介
Use this guide to remove or replace one of the two vacuum motors on the Karcher Carpet Cleaner 10066730.
Follow this same procedure to remove the opposite vacuum motor.
Note: Before beginning repairs, disconnect the device from power, disconnect all hoses, drain and depressurize the system, and let the device cool if the heater was recently used.
你所需要的
Lower the device down so it is laying on its backside, bottom facing out.
Use a 7/16 inch socket and wrench to remove the four bolts, nuts, and washers securing the vacuum motor cover to the base.
2等其他人完成本指南。
