跳转到主内容
KPN Arizona Comfort Replacement
你所需要的
  1. KPN Arizona Comfort Replacement, KPN Arizona Comfort: 步骤 1 中的图像 1,3 KPN Arizona Comfort Replacement, KPN Arizona Comfort: 步骤 1 中的图像 2,3 KPN Arizona Comfort Replacement, KPN Arizona Comfort: 步骤 1 中的图像 3,3
    • Hold the phone with one hand and apply a slight pressure on the battery lid with your other hand.
    • Now you can slide open the battery lid.
  2. KPN Arizona Comfort Replacement: 步骤 2 中的图像 1,1
    • Lift out both batteries with a prying movement.
  3. KPN Arizona Comfort Replacement: 步骤 3 中的图像 1,3 KPN Arizona Comfort Replacement: 步骤 3 中的图像 2,3 KPN Arizona Comfort Replacement: 步骤 3 中的图像 3,3
    • Remove the following two Phillips #00 screws securing the back casing to the front.
  4. KPN Arizona Comfort Replacement: 步骤 4 中的图像 1,3 KPN Arizona Comfort Replacement: 步骤 4 中的图像 2,3 KPN Arizona Comfort Replacement: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to pry the front from the backside.
    • Start prying at the bottom and work your way around the device.
    • Do this for every 3 cm all around.
    • If you apply too much pressure or use a sharp tool, this might damage the casing.
  5. KPN Arizona Comfort Replacement: 步骤 5 中的图像 1,3 KPN Arizona Comfort Replacement: 步骤 5 中的图像 2,3 KPN Arizona Comfort Replacement: 步骤 5 中的图像 3,3
    • Flip the circuit board from the backside of the phone to the frontside of the phone by tilting it on the long edge
    • Make sure you do this gesture slowly and gently so the wires will not detach.
  6. KPN Arizona Comfort Replacement: 步骤 6 中的图像 1,3 KPN Arizona Comfort Replacement: 步骤 6 中的图像 2,3 KPN Arizona Comfort Replacement: 步骤 6 中的图像 3,3
    • You are now facing the back side. Apply a little bit of pressure with the plastic opening tool on the back of the speaker so the the speaker can pop out.
    • The speaker is still attached with a wire, do not pull this.
  7. KPN Arizona Comfort Replacement: 步骤 7 中的图像 1,2 KPN Arizona Comfort Replacement: 步骤 7 中的图像 2,2
    • Use a soldering iron to heat up the solder connected to the electric wire.
    • When the solder is fluid, carefully pull the electric wire loose.
  8. KPN Arizona Comfort Replacement: 步骤 8 中的图像 1,2 KPN Arizona Comfort Replacement: 步骤 8 中的图像 2,2
    • Replace the broken speaker of the phone and solder it back in place.
结论
To reassemble your device, follow these instructions from step 6 in reverse order.
另外一个人完成了本指南。
Maite
于03/08/17注册
131 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 20
总计 563
