当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
Beneath the covers are screws.
Use the iPod pry tool to remove the outer screen.
Two screws are now visible.
Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
Rotate the phone 180 degrees.
Grab the flexible circuit with tweezers (or use your fingers if you can manage a firm grip).
Pull the flexible circuit to towards you to separate the front LCD screen from the phone.
Firmly pull the flexible circuit from the connector.
Be careful not to damage the flexible circuit.
The front LCD screen should now be separate from the phone.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
