跳转到主内容
KATCHY Insect Trap Disassembly and Clean
你所需要的
  1. KATCHY Insect Trap Disassembly and Clean, KATCHY Insect Trap Disassembly and Clean: 步骤 1 中的图像 1,2 KATCHY Insect Trap Disassembly and Clean, KATCHY Insect Trap Disassembly and Clean: 步骤 1 中的图像 2,2
    • Unplug the power plug from the device.
  2. KATCHY Insect Trap Disassembly and Clean: 步骤 2 中的图像 1,1
    • Open the tray lid to remove the used insect trap.
  3. KATCHY Insect Trap Disassembly and Clean: 步骤 3 中的图像 1,2 KATCHY Insect Trap Disassembly and Clean: 步骤 3 中的图像 2,2
    • Flip the device upside down while leaving the tray lid open.
  4. KATCHY Insect Trap Disassembly and Clean: 步骤 4 中的图像 1,1
    • Remove the mesh from the base.
  5. KATCHY Insect Trap Disassembly and Clean: 步骤 5 中的图像 1,1
    • Unlock the vent and UV light bar.
  6. KATCHY Insect Trap Disassembly and Clean: 步骤 6 中的图像 1,2 KATCHY Insect Trap Disassembly and Clean: 步骤 6 中的图像 2,2
    • Optional: Push the circuit cover case away from the clip to unclip and clean.
  7. KATCHY Insect Trap Disassembly and Clean: 步骤 7 中的图像 1,2 KATCHY Insect Trap Disassembly and Clean: 步骤 7 中的图像 2,2
    • Flip the device so that it is no longer upside down.
    • If the top cover is stuck, grab onto the base and push the cover out with your thumb.
  8. KATCHY Insect Trap Disassembly and Clean: 步骤 8 中的图像 1,1
    • Be careful not to damage the wire connecting it to the base. They should be connected still.
  9. KATCHY Insect Trap Disassembly and Clean: 步骤 9 中的图像 1,2 KATCHY Insect Trap Disassembly and Clean: 步骤 9 中的图像 2,2
    • (Extra) Two screws are protecting the circuit board if you want to do something with it.
  10. KATCHY Insect Trap Disassembly and Clean: 步骤 10 中的图像 1,1
    • Double-check that the fan has no dust to ensure the motor will run more efficiently with less dust.
结论
To reassemble your device, follow these instructions in reverse order. Plug the power supply into the device and check if everything works. The UV light should display like normal.
2等其他人完成本指南。
Ryan
于03/20/24注册
244 声望
撰写一个指南
团队
CSU Los Angeles, Team 77-77, Harris Spring 2024 CSU Los Angeles, Team 77-77, Harris Spring 2024 的会员
CSULA-HARRIS-S24S77G77
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 39
过去 30 天: 157
总计 2,551
