跳转到主内容
Jura Impressa S model backpanel
你所需要的
  1. Jura Impressa S model backpanel, How to open a Jura Impressa S model cover: 步骤 1 中的图像 1,2 Jura Impressa S model backpanel, How to open a Jura Impressa S model cover: 步骤 1 中的图像 2,2
    • Always remove the power cord from the wall outlet.
    • Lift out the coffee tray
    • Remove the lid sealing the coffee bean container
    • Remove all of the coffee beans you can possibly remove.
    • Pull the adjuster of the coffee bean grinder straight up
    • Remove the four T15 Torx screws
  2. Jura Impressa S model backpanel: 步骤 2 中的图像 1,2 Jura Impressa S model backpanel: 步骤 2 中的图像 2,2
    • Remove the cup heat plate.
    • It can be opened like a book.
    • Below the cup heat plate there are three more T15 Torx screws. Remove them.
  3. Jura Impressa S model backpanel: 步骤 3 中的图像 1,1
    • The top cover is now free. Lift ´er up and set ´er aside.
  4. Jura Impressa S model backpanel, Jura Impressa S model backpanel: 步骤 4 中的图像 1,3 Jura Impressa S model backpanel, Jura Impressa S model backpanel: 步骤 4 中的图像 2,3 Jura Impressa S model backpanel, Jura Impressa S model backpanel: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    购买
    • The backpanel is secured with two proprietary screws with oval head. They seem to be rivets, but in fact are screws. The only purpose is, to keep us out of our own devices. You can remove them using an oval drive bit. (Part of some IFixit tool collections or available at a Jura provider or iFixit). In a pitch try needle nose pliers. Here a DIY guide.
    • Remove the two oval head screws on the lower edge of the backpanel.
    • Lift the panel up.
结论
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
VauWeh
于10/19/15注册
201,734 声望
创作了246篇指南
团队
Repair is War on Entropy Repair is War on Entropy 的会员
Community
25 名成员
创作了1,097篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 711
