跳转到主内容
Jura Drainage valve (2)
你所需要的
  1. Jura Drainage valve (2), Jura Drainage valve (2): 步骤 1 中的图像 1,3 Jura Drainage valve (2), Jura Drainage valve (2): 步骤 1 中的图像 2,3 Jura Drainage valve (2), Jura Drainage valve (2): 步骤 1 中的图像 3,3
    • The brewing group has already been removed and disassembled. Now it's time for the drainage valve.
    • There will be many pictures
    • All you need a small flathead screwdriver.
  2. Jura Drainage valve (2): 步骤 2 中的图像 1,3 Jura Drainage valve (2): 步骤 2 中的图像 2,3 Jura Drainage valve (2): 步骤 2 中的图像 3,3
    • Images front and back
  3. Jura Drainage valve (2): 步骤 3 中的图像 1,3 Jura Drainage valve (2): 步骤 3 中的图像 2,3 Jura Drainage valve (2): 步骤 3 中的图像 3,3
    • Pull off the clamp and pull out the inlet hose. At the end there is a seal, it often gets stuck in the drainage valve. Swap them out when reassembling.
  4. Jura Drainage valve (2): 步骤 4 中的图像 1,3 Jura Drainage valve (2): 步骤 4 中的图像 2,3 Jura Drainage valve (2): 步骤 4 中的图像 3,3
    • Pull out the clip on the docking tube
    • Pry out the valve body. Make sure the white cap slides out of its hole.
    • Detach the docking nozzle.
  5. Jura Drainage valve (2): 步骤 5 中的图像 1,3 Jura Drainage valve (2): 步骤 5 中的图像 2,3 Jura Drainage valve (2): 步骤 5 中的图像 3,3
    • Detailed photos.
    • The position of the sealing rings are marked green in picture 3.
    • The sealing ring on the docking socket is marked in red in picture 2. It is especially important. It's a little thinner than the other two.
    • The brackets are marked in red.
  6. Jura Drainage valve (2): 步骤 6 中的图像 1,3 Jura Drainage valve (2): 步骤 6 中的图像 2,3 Jura Drainage valve (2): 步骤 6 中的图像 3,3
    • Here all the parts of the valve.
  7. Jura Drainage valve (2): 步骤 7 中的图像 1,1
    • Here is the entire valve in one picture
  8. Jura Drainage valve (2): 步骤 8 中的图像 1,3 Jura Drainage valve (2): 步骤 8 中的图像 2,3 Jura Drainage valve (2): 步骤 8 中的图像 3,3
    • Reassembly
    • When assembling, make sure that the lips of the seals point to the pressure side, i.e. inward, and the flat side outward.
    • When installing, make sure that the pressure hose runs through the slot in the valve carrier.
结论
Follow the steps in reverse order to reassemble your device.
3等其他人完成本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Schwarzstein
于07/15/13注册
2,813 声望
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 53
过去 30 天: 187
总计 7,801
