跳转到主内容
Jumper Angelsounds JPD-100S Indicator Light Replacement
你所需要的
  1. Jumper Angelsounds JPD-100S Indicator Light Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S Indicator Light Replacement: 步骤 2 中的图像 1,2 Jumper Angelsounds JPD-100S Indicator Light Replacement: 步骤 2 中的图像 2,2
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S Indicator Light Replacement: 步骤 3 中的图像 1,1
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S Indicator Light Replacement: 步骤 4 中的图像 1,2 Jumper Angelsounds JPD-100S Indicator Light Replacement: 步骤 4 中的图像 2,2
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S Indicator Light Replacement: 步骤 5 中的图像 1,2 Jumper Angelsounds JPD-100S Indicator Light Replacement: 步骤 5 中的图像 2,2
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S Indicator Light Replacement: 步骤 6 中的图像 1,1
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S Indicator Light Replacement: 步骤 7 中的图像 1,1
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S Indicator Light Replacement, Indicator Light: 步骤 8 中的图像 1,1
    • Place the motherboard in a position that allows access it's underside.
    • Pre-heat the soldering iron.
  9. Jumper Angelsounds JPD-100S Indicator Light Replacement: 步骤 9 中的图像 1,3 Jumper Angelsounds JPD-100S Indicator Light Replacement: 步骤 9 中的图像 2,3 Jumper Angelsounds JPD-100S Indicator Light Replacement: 步骤 9 中的图像 3,3
    • Desoldering
    • If steam is created when the soldering iron is touched to a wet sponge then the soldering iron is hot enough.
    • Use the soldering iron and soldering vacuum to unsolder the indicator light leads.
    • Plastic spacer holding indicator light may burn.
结论
Deron Rogers
于08/31/15注册
271 声望
创作了2篇指南
团队
USF Tampa, Team 6-1, Remmell Fall 2015 USF Tampa, Team 6-1, Remmell Fall 2015 的会员
USFT-REMMELL-F15S6G1
6 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 201
