跳转到主内容
Jumper Angelsounds JPD-100S Headphone Jacks Replacement
你所需要的
  1. Jumper Angelsounds JPD-100S Headphone Jacks Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 2 中的图像 1,2 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 2 中的图像 2,2
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 3 中的图像 1,1
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 4 中的图像 1,2 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 4 中的图像 2,2
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 5 中的图像 1,2 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 5 中的图像 2,2
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 6 中的图像 1,1
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 7 中的图像 1,1
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S Headphone Jacks Replacement, Headphone Jacks: 步骤 8 中的图像 1,1
    • Take the battery connector out of the battery compartment.
  9. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 9 中的图像 1,1
    • Preheat the soldering iron .
    • Locate the wires that connect to the transducer.
    • Use a soldering iron and solder vacuum to unsolder the wires connected to the transducer.
  10. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 10 中的图像 1,2 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 10 中的图像 2,2
    • Place the motherboard in a position that allows easy access to the jacks.
  11. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 11 中的图像 1,3 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 11 中的图像 2,3 Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 11 中的图像 3,3
    • Desolder the three solder joints securing each of the headphone jacks.
    • Try not to melt the motherboard when removing solder that secures the jacks.
  12. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: 步骤 12 中的图像 1,1
    • Remove the jacks by pulling them out of the motherboard.
结论
Yessika Lugo
于08/31/15注册
113 声望
撰写一个指南
团队
USF Tampa, Team 6-1, Remmell Fall 2015 USF Tampa, Team 6-1, Remmell Fall 2015 的会员
USFT-REMMELL-F15S6G1
6 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 384
