跳转到主内容
Jumper Angelsounds JPD-100S Battery Cable Replacement
你所需要的
  1. Jumper Angelsounds JPD-100S Battery Cable Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S Battery Cable Replacement: 步骤 2 中的图像 1,2 Jumper Angelsounds JPD-100S Battery Cable Replacement: 步骤 2 中的图像 2,2
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S Battery Cable Replacement: 步骤 3 中的图像 1,1
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S Battery Cable Replacement: 步骤 4 中的图像 1,2 Jumper Angelsounds JPD-100S Battery Cable Replacement: 步骤 4 中的图像 2,2
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S Battery Cable Replacement: 步骤 5 中的图像 1,2 Jumper Angelsounds JPD-100S Battery Cable Replacement: 步骤 5 中的图像 2,2
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S Battery Cable Replacement: 步骤 6 中的图像 1,1
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S Battery Cable Replacement: 步骤 7 中的图像 1,1
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S Battery Cable Replacement, Battery Cable: 步骤 8 中的图像 1,2 Jumper Angelsounds JPD-100S Battery Cable Replacement, Battery Cable: 步骤 8 中的图像 2,2
    • Preheat soldering iron.
    • Locate the battery cable leads on the motherboard.
  9. Jumper Angelsounds JPD-100S Battery Cable Replacement: 步骤 9 中的图像 1,2 Jumper Angelsounds JPD-100S Battery Cable Replacement: 步骤 9 中的图像 2,2
    • Use a soldering iron and solder vacuum to unsolder the battery cable leads.
  10. Jumper Angelsounds JPD-100S Battery Cable Replacement: 步骤 10 中的图像 1,1
    • Remove the battery cables by pulling them out of the motherboard.
结论
团队
USF Tampa, Team 6-1, Remmell Fall 2015 USF Tampa, Team 6-1, Remmell Fall 2015 的会员
USFT-REMMELL-F15S6G1
6 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 403
