当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Pass the thread through the needle eye.
Loop the threading through the two tension posts, making sure you stay in the grooves of the wheels.
Continue the threading, weaving through the pull-off lever.
Adjust the thread pull-off lever as well as adjust the position of the nipper bar block to the left or the right.
Tighten the thread on the top loop near the nipper releasing knurled thumb nut.
Weave threading through the working arm and have it ready to insert through the eye of the needle.
Again, keep the thread along the groove of the wheel before slipping it through the eye of the needle.
Using the flathead screwdriver, slide the needle up into the slot, with the indented side facing in and tighten until the needle cannot shift.
Insert the thread through the eye of the needle, and you are ready for sewing.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与1其他贡献者
于02/04/19注册
196 声望
撰写一个指南
徽章: 3
EWU-MUNOZ-W19S27G8
1 名成员
创作了1篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 123
