跳转到主内容
Juki Chainstitch Machine Thread and Needle Replacement
你所需要的
  1. Juki Chainstitch Machine Thread and Needle Replacement, Thread and Needle: 步骤 1 中的图像 1,1
    • Pass the thread through the needle eye.
  2. Juki Chainstitch Machine Thread and Needle Replacement: 步骤 2 中的图像 1,1
    • Loop the threading through the two tension posts, making sure you stay in the grooves of the wheels.
  3. Juki Chainstitch Machine Thread and Needle Replacement: 步骤 3 中的图像 1,1
    • Continue the threading, weaving through the pull-off lever.
  4. Juki Chainstitch Machine Thread and Needle Replacement: 步骤 4 中的图像 1,2 Juki Chainstitch Machine Thread and Needle Replacement: 步骤 4 中的图像 2,2
    • Adjust the thread pull-off lever as well as adjust the position of the nipper bar block to the left or the right.
  5. Juki Chainstitch Machine Thread and Needle Replacement: 步骤 5 中的图像 1,1
    • Tighten the thread on the top loop near the nipper releasing knurled thumb nut.
  6. Juki Chainstitch Machine Thread and Needle Replacement: 步骤 6 中的图像 1,1
    • Weave threading through the working arm and have it ready to insert through the eye of the needle.
  7. Juki Chainstitch Machine Thread and Needle Replacement: 步骤 7 中的图像 1,1
    • Again, keep the thread along the groove of the wheel before slipping it through the eye of the needle.
  8. Juki Chainstitch Machine Thread and Needle Replacement: 步骤 8 中的图像 1,1
    • Using the flathead screwdriver, slide the needle up into the slot, with the indented side facing in and tighten until the needle cannot shift.
  9. Juki Chainstitch Machine Thread and Needle Replacement: 步骤 9 中的图像 1,1
    • Insert the thread through the eye of the needle, and you are ready for sewing.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 12
总计 131
