跳转到主内容
加入维修社区 - 创建账户
Jolla C or Intex Aqua Fish Teardown
你所需要的
  1. Jolla C or Intex Aqua Fish Teardown, Phone & Back Cover: 步骤 1 中的图像 1,2 Jolla C or Intex Aqua Fish Teardown, Phone & Back Cover: 步骤 1 中的图像 2,2
    • Remove the back cover, starting at the bottom right corner with your nail or a prying tool
    询问修复机器人
    添加评论
  2. Jolla C or Intex Aqua Fish Teardown, Battery, Sims & SD: 步骤 2 中的图像 1,2 Jolla C or Intex Aqua Fish Teardown, Battery, Sims & SD: 步骤 2 中的图像 2,2
    • Remove the battery
    • Remove all sim-cards
    • Remove the microSD-card
    询问修复机器人
    添加评论
  3. Jolla C or Intex Aqua Fish Teardown, Middle Cover: 步骤 3 中的图像 1,3 Jolla C or Intex Aqua Fish Teardown, Middle Cover: 步骤 3 中的图像 2,3 Jolla C or Intex Aqua Fish Teardown, Middle Cover: 步骤 3 中的图像 3,3
    • Remove all 14 cross-head screws
    • Use a prying tool to separate the middle cover from the phone, working from the bottom slowly up to the top
    • Watch out for the power and volume buttons, which probably fall out of the device.
    询问修复机器人
    添加评论
  4. Jolla C or Intex Aqua Fish Teardown, Top Circuit Board: 步骤 4 中的图像 1,3 Jolla C or Intex Aqua Fish Teardown, Top Circuit Board: 步骤 4 中的图像 2,3 Jolla C or Intex Aqua Fish Teardown, Top Circuit Board: 步骤 4 中的图像 3,3
    • Remove all cross-head screws
    • Remove the antenna wire from the circuit board
    • Pry loose the power & volume button part at the side (it is stuck to the phone with sticky tape) and pull it out
    • Pull out the connector for the bottom cuircuit board
    • Pull out the screen connector
    • Pry loose the connector for the proximity sensor etc
    • Now you can remove the top circuit board
    • Remove the main and front camera connectors
    询问修复机器人
    添加评论
  5. Jolla C or Intex Aqua Fish Teardown, Bottom Cuircuit Board: 步骤 5 中的图像 1,2 Jolla C or Intex Aqua Fish Teardown, Bottom Cuircuit Board: 步骤 5 中的图像 2,2
    • Remove the antenna cable
    • Remove the speaker and vibration motor from the phone
    • Both items are stuck to the phone and the cables are very fragile. I broke one of the connections when removing the speaker for a second time, as seen in the second picture. It is possible to solder it back on
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Jos Wagenmakers
于03/20/17注册
185 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 83
总计 3,129
