跳转到主内容
John Frieda JFHA5R Reset and Test Buttons Replacement
你所需要的
  1. John Frieda JFHA5R Reset and Test Buttons Replacement, Reset and Test Buttons: 步骤 1 中的图像 1,1
    • Make sure the Salon Shape brush is unplugged, and do not use metals once you have pried open the power plug.
    • Unscrew the two screws using a 3.0 mm bit triangle head on the back of the power plug.
  2. John Frieda JFHA5R Reset and Test Buttons Replacement: 步骤 2 中的图像 1,1
    • Use the spudger along either side to open up the power plug.
    • As the power plug is opened, the caution sticker on top of the plug will rip.
  3. John Frieda JFHA5R Reset and Test Buttons Replacement: 步骤 3 中的图像 1,1
    • Slide slightly up to remove the back cover of the power plug.
  4. John Frieda JFHA5R Reset and Test Buttons Replacement: 步骤 4 中的图像 1,1
    • Remove the red reset button by pulling it to the right.
  5. John Frieda JFHA5R Reset and Test Buttons Replacement: 步骤 5 中的图像 1,1
    • Pull slightly left then up to remove the yellow test button.
结论
Lindsey Farley
于11/08/17注册
113 声望
撰写一个指南
团队
IUPUI, Team S5-G1, Baechle Fall 2017 IUPUI, Team S5-G1, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S5G1
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 9
总计 468
