跳转到主内容
加入维修社区 - 创建账户
John Deere LA120 Tire Replacement
你所需要的
    1. John Deere LA120 Tire Replacement, Tire: 步骤 1 中的图像 1,3 John Deere LA120 Tire Replacement, Tire: 步骤 1 中的图像 2,3 John Deere LA120 Tire Replacement, Tire: 步骤 1 中的图像 3,3
      • Disconnect the battery before beginning repairs. Generally, a 9mm or 10mm will be the correct bolt sizes for most batteries. Check your owner's manual for correct size.
      • Remove the ignition key.
      • Make sure the brake is engaged and locked.
      询问修复机器人
      添加评论
    2. John Deere LA120 Tire Replacement: 步骤 2 中的图像 1,3 John Deere LA120 Tire Replacement: 步骤 2 中的图像 2,3 John Deere LA120 Tire Replacement: 步骤 2 中的图像 3,3
      • Deflate the tire if it is holding air.
      • Use a heat gun or hair dryer to loosen the wheel hub cover as they can become hard over time and difficult to remove.
      • Should the hub cover become damaged during removal, the hub cover for your model should be available from local lawn/tractor/hardware supply stores or online retailers.
      询问修复机器人
      添加评论
    3. John Deere LA120 Tire Replacement: 步骤 3 中的图像 1,2 John Deere LA120 Tire Replacement: 步骤 3 中的图像 2,2
      • Securely raise the base of the lawnmower with a jack.
      • A 2x4 piece of wood is placed under the jack point to protect the body of the mower. This is NOT required. Should you choose to do this, use caution as the wood must be placed evenly and not prone to cracking.
      • Support the mower with jack stands to provide extra support and safety.
      询问修复机器人
      添加评论
    4. John Deere LA120 Tire Replacement: 步骤 4 中的图像 1,3 John Deere LA120 Tire Replacement: 步骤 4 中的图像 2,3 John Deere LA120 Tire Replacement: 步骤 4 中的图像 3,3
      • Remove the tire retaining clip.
      • Remove the washer from the axle.
      • Remove the tire.
      询问修复机器人
      添加评论
    5. John Deere LA120 Tire Replacement: 步骤 5 中的图像 1,2 John Deere LA120 Tire Replacement: 步骤 5 中的图像 2,2
      • Take the tire and rim along with the replacement tire to a local auto shop and have them mount the tire for a small fee.
      询问修复机器人
      添加评论
    6. John Deere LA120 Tire Replacement: 步骤 6 中的图像 1,3 John Deere LA120 Tire Replacement: 步骤 6 中的图像 2,3 John Deere LA120 Tire Replacement: 步骤 6 中的图像 3,3
      • Reinstall the tire to the mower.
      • Reinsert the washer and retaining pin.
      • Replace the tire hub cover.
      询问修复机器人
      添加评论
    7. John Deere LA120 Tire Replacement: 步骤 7 中的图像 1,3 John Deere LA120 Tire Replacement: 步骤 7 中的图像 2,3 John Deere LA120 Tire Replacement: 步骤 7 中的图像 3,3
      • Remove the jack stands.
      • Lower the jack and move it out from under the mower.
      • Reattach the battery.
      • Verify the tire is inflated and start the mower.
      询问修复机器人
      添加评论
结论
At completion you should:
  • Check for leaks and correct tire fitment.
  • Reattach the battery and the ignition key.
  • Take your mower for a final test drive.
Congratulations! You're done! Happy mowing!
取消:我没有完成这个指南。
Sumeet Pamar
于09/23/25注册
145 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 37
总计 308
