跳转到主内容
Jewelry Clasp Replacement
你所需要的
  1. Jewelry Clasp Replacement, Clasp: 步骤 1 中的图像 1,2 Jewelry Clasp Replacement, Clasp: 步骤 1 中的图像 2,2
    • Locate the jump ring, which is the link between the clasp and the chain.
    • On the jump ring, locate the slit.
  2. Jewelry Clasp Replacement: 步骤 2 中的图像 1,3 Jewelry Clasp Replacement: 步骤 2 中的图像 2,3 Jewelry Clasp Replacement: 步骤 2 中的图像 3,3
    • Use one pair of flat nose pliers to gently grip the jump ring on one side of the slit.
    • Use the other pair of flat nose pliers to grip the jump ring on the opposite side of the slit.
  3. Jewelry Clasp Replacement: 步骤 3 中的图像 1,2 Jewelry Clasp Replacement: 步骤 3 中的图像 2,2
    • To create a gap large enough to remove the clasp, twist one hand away from you while simultaneously twisting the other hand towards you.
    • Stop twisting once the gap is large enough for the clasp to be removed, and remove the old clasp.
    • Be careful not to twist outwards with the pliers or you will disfigure the jump ring.
  4. Jewelry Clasp Replacement: 步骤 4 中的图像 1,3 Jewelry Clasp Replacement: 步骤 4 中的图像 2,3 Jewelry Clasp Replacement: 步骤 4 中的图像 3,3
    • If a new jump ring is needed, first remove the chain from the old jump ring.
    • Then, grab a new jump ring, locate its slit, and twist it open using the two pliers once again.
  5. Jewelry Clasp Replacement: 步骤 5 中的图像 1,3 Jewelry Clasp Replacement: 步骤 5 中的图像 2,3 Jewelry Clasp Replacement: 步骤 5 中的图像 3,3
    • Slide the chain and the clasp onto the new jump ring.
    • To close the jump ring, use one pair of flat nose pliers to grab either side of the slit.
    • Begin twisting the ends of the jump ring toward each other until they meet once again.
  6. Jewelry Clasp Replacement: 步骤 6 中的图像 1,3 Jewelry Clasp Replacement: 步骤 6 中的图像 2,3 Jewelry Clasp Replacement: 步骤 6 中的图像 3,3
    • If the gap remains, twist the jump ring so that the two ends are not aligned.
    • Keeping one pair of pliers gripped on the jump ring, use the other pair to gently squeeze the rim of the ring bringing the ends closer together.
    • Once this is done, return the nose pliers to their original position on either side of the slit and twist until the two ends meet.
    • Be careful not to squeeze the rim too tightly or the jump ring will be disfigured.
结论
Enjoy your newly wearable piece of jewelry! If another clasp breaks, you know exactly how to replace it.
3等其他人完成本指南。
Breanna Tran
于04/09/15注册
239 声望
撰写一个指南
团队
Cal Poly, Team 30-6, Green Spring 2015 Cal Poly, Team 30-6, Green Spring 2015 的会员
CPSU-GREEN-S15S30G6
2 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 25
过去 30 天: 78
总计 6,075
