跳转到主内容
Jensen JTA-230 Speaker Replacement
你所需要的
    • First, open the dust cover and grab it by the hinges and pull up until it slides out.
    • Then, using a screwdriver unscrew the 3 screws on each side and remove the top layer of the record player. The top should pop out.
  1. Jensen JTA-230 Speaker Replacement: 步骤 2 中的图像 1,2 Jensen JTA-230 Speaker Replacement: 步骤 2 中的图像 2,2
    • You should see the speakers(one on both side). From here, you want to unscrew the three screws holding them in place, using the same head as the previous step.
  2. Jensen JTA-230 Speaker Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the speakers from the device, being careful not to harm any components of the speaker.
  3. Jensen JTA-230 Speaker Replacement: 步骤 4 中的图像 1,1
    • Once the speaker is out of the device, you should use a soldering iron to take off the wires on the current broken speaker, and put them to the new speaker using a soldering iron.
结论
John Roche
于03/02/16注册
175 声望
撰写一个指南
团队
UMass Dartmouth, Team 8-8, Botvin Spring 2016 UMass Dartmouth, Team 8-8, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G8
3 名成员
创作了5篇指南
一条评论
What type of speakers do I need to buy?
Isaac Bott - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 555
