跳转到主内容
Jensen JTA-230 Motor Replacement
你所需要的
  1. Jensen JTA-230 Motor Replacement, Turntable Platter: 步骤 1 中的图像 1,1
    • Remove Cover from record player.
  2. Jensen JTA-230 Motor Replacement: 步骤 2 中的图像 1,1
    • Remove the 4 rubber plugs which hold the turntable platter in place
    • Gently but firmly pull the turntable platter off the axle.
  3. Jensen JTA-230 Motor Replacement: 步骤 3 中的图像 1,1
    • Take replacement turntable platter affix it firmly and gently to the axle.
  4. Jensen JTA-230 Motor Replacement: 步骤 4 中的图像 1,1
    • Replace rubber plugs
  5. Jensen JTA-230 Motor Replacement: 步骤 5 中的图像 1,1
    • Replace Cover
  6. Jensen JTA-230 Motor Replacement, Motor: 步骤 6 中的图像 1,2 Jensen JTA-230 Motor Replacement, Motor: 步骤 6 中的图像 2,2
    • After removal of the turntable platter, 3 small screws can be seen. Remove the 3 screws which hold the motor in place.
    • On both the right and left side, there are 3 screws, remove each of them.
  7. Jensen JTA-230 Motor Replacement: 步骤 7 中的图像 1,2 Jensen JTA-230 Motor Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Gently Pull the top off of the sides and flip over to reveal the circuitry.
    • To remove the top entirely, remove each electrical connection with a pair of tweezers. There are 3, each connecting to the speakers.
  8. Jensen JTA-230 Motor Replacement: 步骤 8 中的图像 1,1
    • Remove the Motor from the record player
    • Using a soldering iron, remove the motor from the circuitry.
    • Replace motor with new one.
结论
Robert Wilcox
于03/04/16注册
227 声望
创作了2篇指南
团队
UMass Dartmouth, Team 8-8, Botvin Spring 2016 UMass Dartmouth, Team 8-8, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G8
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 25
总计 1,995
