跳转到主内容
Jensen JTA-230 Cartridge/Needle Replacement
  1. Jensen JTA-230 Cartridge/Needle Replacement, Cartridge/Needle: 步骤 1 中的图像 1,1
    • Open the dust cover
  2. Jensen JTA-230 Cartridge/Needle Replacement: 步骤 2 中的图像 1,1
    • Next, lift up the clip that holds the tone arm in place and lift the tone arm out.
  3. Jensen JTA-230 Cartridge/Needle Replacement: 步骤 3 中的图像 1,1
    • The cartridge and needle is the red piece at the end of the tone arm. To remove it, simply grab the end on each side and pull back slowly. The piece should slide right off the tone arm
  4. Jensen JTA-230 Cartridge/Needle Replacement: 步骤 4 中的图像 1,1
    • Once you have the replacement piece it goes on slight different. Instead of it sliding back on, it clips back on. Once the new piece is secured back on it is good to go.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 8-8, Botvin Spring 2016 UMass Dartmouth, Team 8-8, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G8
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 32
总计 5,230
