简介
This video guide will show you how to change your differential fluid/ gear oil. Not only that but also clean the inside of the housing and check for damage.
- CAUTION: If you have never jacked up your vehicle before, follow this guide.
你所需要的
视频概述
Place a bucket under the differential
Use a hammer to tap the cover and let the fluid drain out
Then, remove the cover
Use brake parts cleaner to clean the inside of the housing
Wipe it down with paper towels and let it dry
Clean the cover with brake parts cleaner, both inside and outside
Make sure to remove any old RTV or gasket material from the mating surface
Align the cover with the differential housing and press it into place
Reinstall the bolts and the metal tag you removed earlier, tightening them in a criss-cross pattern to ensure even pressure on the gasket
After letting the RTV dry for a short time, remove the fill plug and fill the differential with gear oil until it starts to spill out of the fill hole
Replace the fill plug and clean up any excess oil.
2等其他人完成本指南。
