跳转到主内容
Jeans 2-Hole Button Replacement
你所需要的
  1. Jeans 2-Hole Button Replacement, 2-Hole Button: 步骤 1 中的图像 1,1
    • Find a thread color that matches the fabric you are sewing the button on to.
  2. Jeans 2-Hole Button Replacement: 步骤 2 中的图像 1,1
    • Loop the thread through the eye of the needle.
    • Tie a small knot around the eye of the needle with the thread.
    • Make sure the knot is tight!
  3. Jeans 2-Hole Button Replacement: 步骤 3 中的图像 1,1
    • Thread the needle through the fabric from the inside out.
    • Tie a knot at the end of the thread after pulling most of it through the fabric.
  4. Jeans 2-Hole Button Replacement: 步骤 4 中的图像 1,3 Jeans 2-Hole Button Replacement: 步骤 4 中的图像 2,3 Jeans 2-Hole Button Replacement: 步骤 4 中的图像 3,3
    • Sew the thread in a small 'x' where you would like to place the button.
    • If you don't want to sew, then mark the spot with a white fabric marker.
  5. Jeans 2-Hole Button Replacement: 步骤 5 中的图像 1,3 Jeans 2-Hole Button Replacement: 步骤 5 中的图像 2,3 Jeans 2-Hole Button Replacement: 步骤 5 中的图像 3,3
    • Place the button over the small stitched 'x' or fabric marker spot.
    • Thread the needle through the left hole of the button from the inside out.
    • Pull the needle and thread all the way through the fabric.
    • If you can't find the hole of the button, thread the needle through the fabric first and then through the button hole.
  6. Jeans 2-Hole Button Replacement: 步骤 6 中的图像 1,3 Jeans 2-Hole Button Replacement: 步骤 6 中的图像 2,3 Jeans 2-Hole Button Replacement: 步骤 6 中的图像 3,3
    • Cross the needle over to the right hole of the button.
    • Thread the needle all the way through the fabric.
    • This step creates the first stitch.
  7. Jeans 2-Hole Button Replacement: 步骤 7 中的图像 1,1
    • Repeat Steps 6-7 four to five times, until you have a secure button.
  8. Jeans 2-Hole Button Replacement: 步骤 8 中的图像 1,1
    • Create a thread shank on the inside of the fabric by looping the thread around a stitch.
    • Pull the thread all the way through the hole until it is tight.
    • Repeat this 2-3 times.
    • Tie a knot after the final stitch to secure the stitches.
  9. Jeans 2-Hole Button Replacement: 步骤 9 中的图像 1,2 Jeans 2-Hole Button Replacement: 步骤 9 中的图像 2,2
    • Use fabric scissors to cut off excess thread.
结论
After cutting the remaining thread, your button stays on your jeans.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 34
总计 495
