跳转到主内容
Jean Zipper Repair
你所需要的
  1. Jean Zipper Repair, Jean Zipper Repair: 步骤 1 中的图像 1,3 Jean Zipper Repair, Jean Zipper Repair: 步骤 1 中的图像 2,3 Jean Zipper Repair, Jean Zipper Repair: 步骤 1 中的图像 3,3
    • Place your zipper in the upright position before trying to connect it to the zipper tracks.
    • If one of the zipper sides can be attached back on the tracks without any help, SKIP to Step 3.
    • If your zipper cannot be attached to the tracks easily, continue to the next step.
  2. Jean Zipper Repair: 步骤 2 中的图像 1,3 Jean Zipper Repair: 步骤 2 中的图像 2,3 Jean Zipper Repair: 步骤 2 中的图像 3,3
    • Use the flathead screwdriver and place it in between the zipper sides.
    • Twist the flathead screwdriver back and forth while holding the zipper steady.
    • This will allow the zipper side to open wider so the zipper tracks can fit in between the zipper's sides.
  3. Jean Zipper Repair: 步骤 3 中的图像 1,3 Jean Zipper Repair: 步骤 3 中的图像 2,3 Jean Zipper Repair: 步骤 3 中的图像 3,3
    • Attach the zipper to the zipper tracks.
    • Use the hammer to help close the zipper side onto the track.
    • Be sure to check that the zipper is secure on the track. Do this by moving the zipper up and down on the track and tugging on the zipper.
  4. Jean Zipper Repair: 步骤 4 中的图像 1,2 Jean Zipper Repair: 步骤 4 中的图像 2,2
    • Repeat Step 2 for the other side of the zipper.
  5. Jean Zipper Repair: 步骤 5 中的图像 1,1
    • Make sure the tracks are even before hammering down the second side.
    • Pull and tug on the zipper and jeans until the tracks start lining up.
  6. Jean Zipper Repair: 步骤 6 中的图像 1,3 Jean Zipper Repair: 步骤 6 中的图像 2,3 Jean Zipper Repair: 步骤 6 中的图像 3,3
    • Start hammering the top and sides of the zipper to secure the closing.
    • Check to make sure the zipper is attached by moving the zipper up and down.
    • Continue to hammer the top and sides if the tracks aren't connecting when you zip up the jeans.
  7. Jean Zipper Repair: 步骤 7 中的图像 1,3 Jean Zipper Repair: 步骤 7 中的图像 2,3 Jean Zipper Repair: 步骤 7 中的图像 3,3
    • After hammering the zipper, everything should be secure. Move the zipper up and down a few more times to ensure the tracks are even, connecting and staying connected.
结论
Follow these quick 30 minute instructions to save your jeans.
3等其他人完成本指南。
Nadia Simpson
于10/12/20注册
394 声望
创作了2篇指南
一条评论
Thanks for the article that helped me gain more knowledge to fix the zipper of my pants. Now I'm going to pull out my broken pants and practice.
Theresa Almanza - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 36
过去 30 天: 159
总计 9,936
