跳转到主内容
Jazz UltraTab C1059-HL Speaker Replacement
你所需要的
  1. Jazz UltraTab C1059-HL Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 Jazz UltraTab C1059-HL Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Start by removing the back panel.
    • Remove the 4 screws holding the device together: two on the left side, and two on the right side.
    • Using a metal spudger, carefully pry open the case.
    • With the screws gone, the case is held together with clips along the outside edge of the aluminum backplate.
    • Undoing these clips can take a bit of force. Be cautious not to damage the plastic edge of the device.
  2. Jazz UltraTab C1059-HL Speaker Replacement: 步骤 2 中的图像 1,1
    • Place the device on the table with the screen-side down.
  3. Jazz UltraTab C1059-HL Speaker Replacement: 步骤 3 中的图像 1,1
    • This is the Speaker.
    • Remove the two black screws.
  4. Jazz UltraTab C1059-HL Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove black tape from the wires.
    • Keep this tape, you will need it for reassembly.
  5. Jazz UltraTab C1059-HL Speaker Replacement: 步骤 5 中的图像 1,1
    • Using a soldering iron, heat up the spot where the speaker wires connect to the mainboard.
    • Remove Speaker wires when the solder liquifies.
    • Remember to make note of where each wire is connected. When reinstalling the speaker, it is important that the wires are reattached to the same spot.
  6. Jazz UltraTab C1059-HL Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove the speaker.
    • Replace the speaker by following these steps in reverse.
结论
另外一个人完成了本指南。
Tim Poe
于09/26/15注册
361 声望
创作了3篇指南
团队
IUPUI, Team 1-3, Wilson Fall 2015 IUPUI, Team 1-3, Wilson Fall 2015 的会员
IUPUI-WILSON-F15S1G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 95
