跳转到主内容
Jazz UltraTab C1059-HL Screen Replacement
你所需要的
  1. Jazz UltraTab C1059-HL Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • First step is to remove screws from top and bottom of device.
  2. Jazz UltraTab C1059-HL Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the back panel of the device.
    • Be careful not to brake/bend the plastic cover of your device.
  3. Jazz UltraTab C1059-HL Screen Replacement: 步骤 3 中的图像 1,1
    • Upon removing the back panel, place the device screen down on the table.
  4. Jazz UltraTab C1059-HL Screen Replacement: 步骤 4 中的图像 1,1
    • Remove all data strips attached to the motherboard.
  5. Jazz UltraTab C1059-HL Screen Replacement: 步骤 5 中的图像 1,3 Jazz UltraTab C1059-HL Screen Replacement: 步骤 5 中的图像 2,3 Jazz UltraTab C1059-HL Screen Replacement: 步骤 5 中的图像 3,3
    • Remove the tape around the battery.
    • One of these pieces of tape holds down the battery connection to the mainboard.
    • Use the soldering iron to disconnect these wires.
    • You will need to use a tool to pry off the battery. It will have a good amount of adhesive holding it down.
    • Be cautious not to bend the battery when prying.
  6. Jazz UltraTab C1059-HL Screen Replacement: 步骤 6 中的图像 1,1
    • Once the battery is removed, make sure to remove any and all data strips that are attached.
    • Then begin to unscrew the mother board.
  7. Jazz UltraTab C1059-HL Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the motherboard chip off of the device.
  8. Jazz UltraTab C1059-HL Screen Replacement: 步骤 8 中的图像 1,1
    • Your board should look like this after taking all of the components off the screen panel.
  9. Jazz UltraTab C1059-HL Screen Replacement: 步骤 9 中的图像 1,2 Jazz UltraTab C1059-HL Screen Replacement: 步骤 9 中的图像 2,2
    • Remove the Display Module from the screen cover.
  10. Jazz UltraTab C1059-HL Screen Replacement: 步骤 10 中的图像 1,1
    • Now, you can replace your broken or damaged screen!
结论
另外一个人完成了本指南。
团队
IUPUI, Team 1-3, Wilson Fall 2015 IUPUI, Team 1-3, Wilson Fall 2015 的会员
IUPUI-WILSON-F15S1G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 462
