跳转到主内容
Jazz UltraTab C1059-HL Headphone Jack Replacement
你所需要的
  1. Jazz UltraTab C1059-HL Headphone Jack  Replacement, Headphone Jack: 步骤 1 中的图像 1,1
    • Use a Philips screwdriver to remove the four screws: two at the top and two at the bottom of the device.
  2. Jazz UltraTab C1059-HL Headphone Jack  Replacement: 步骤 2 中的图像 1,2 Jazz UltraTab C1059-HL Headphone Jack  Replacement: 步骤 2 中的图像 2,2
    • Place the device screen down on the table and use a pry tool to remove the back panel.
  3. Jazz UltraTab C1059-HL Headphone Jack  Replacement: 步骤 3 中的图像 1,1
    • For your safety, remove the battery.
    • Using a solder iron, remove the wires connecting the battery to the motherboard.
  4. Jazz UltraTab C1059-HL Headphone Jack  Replacement: 步骤 4 中的图像 1,2 Jazz UltraTab C1059-HL Headphone Jack  Replacement: 步骤 4 中的图像 2,2
    • Remove the screw attaching the motherboard to the back panel. Gently remove the motherboard.
  5. Jazz UltraTab C1059-HL Headphone Jack  Replacement: 步骤 5 中的图像 1,1
    • The headphone jack is attached to the motherboard, so the whole thing must be replaced.
    • With the new mother board, use these steps in reverse to reassemble the device.
结论
另外一个人完成了本指南。
Tim Poe
于09/26/15注册
361 声望
创作了3篇指南
团队
IUPUI, Team 1-3, Wilson Fall 2015 IUPUI, Team 1-3, Wilson Fall 2015 的会员
IUPUI-WILSON-F15S1G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 114
