跳转到主内容
Jazz UltraTab C1059-HL Battery Replacement
你所需要的
  1. Jazz UltraTab C1059-HL Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • remove the screws at the four corners of the device.
  2. Jazz UltraTab C1059-HL Battery Replacement: 步骤 2 中的图像 1,2 Jazz UltraTab C1059-HL Battery Replacement: 步骤 2 中的图像 2,2
    • Use a prying tool to pry the back panel from the tablet chassis. Pry the panel at different locations around the device to separate clips.
  3. Jazz UltraTab C1059-HL Battery Replacement: 步骤 3 中的图像 1,1
    • Use a soldering iron to remove power cables from battery. The power cable is shown at the corner of the battery in the picture.
  4. Jazz UltraTab C1059-HL Battery Replacement: 步骤 4 中的图像 1,2 Jazz UltraTab C1059-HL Battery Replacement: 步骤 4 中的图像 2,2
    • Use a tool to carefully pry battery away from chassis. The battery is attached by an adhesive. Slowly pry battery on the side away from the motherboard.
  5. Jazz UltraTab C1059-HL Battery Replacement: 步骤 5 中的图像 1,1
    • You have successfully removed the battery. Put new battery in the same location. Solder the supply wires. Reapply tape in original location.
结论
Austen Shields
于09/26/15注册
101 声望
撰写一个指南
团队
IUPUI, Team 1-3, Wilson Fall 2015 IUPUI, Team 1-3, Wilson Fall 2015 的会员
IUPUI-WILSON-F15S1G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 608
