跳转到主内容
Jazz HDV178 Camcorder Battery Replacement
  1. Jazz HDV178 Camcorder Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • On the back of the camcorder, the side opposite of the flip-out screen, there is a section of grooved plastic with a small arrow.
    • Press down on the grooved plastic with your thumbs.
    • Push the back cover in the direction indicated by the small arrow on the grooved plastic. The back cover should slide right off.
  2. Jazz HDV178 Camcorder Battery Replacement, Battery: 步骤 2 中的图像 1,1
    • Once you have the back cover off, the camcorder should look like this.
    • Look on the battery for a model number to assure that you acquire the correct replacement part.
    • The camcorder model number is located in the red box. Verify that you have a Jazz HDV178.
  3. Jazz HDV178 Camcorder Battery Replacement: 步骤 3 中的图像 1,1
    • Take the battery out by pulling up on the bottom of the battery. You should be pulling from the side of the camera where the wrist strap is attached.
结论
2等其他人完成本指南。
timothy
于01/28/11注册
354 声望
创作了3篇指南
团队
Cal Poly, Team 7-34, Regan Winter 2011 Cal Poly, Team 7-34, Regan Winter 2011 的会员
CPSU-REGAN-W11S7G34
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 3,267
