跳转到主内容
简介
This guide will aid the user in the replacement of the lens for this device. The lens will need to be replaced if it is scratched or cracked. It is important to be careful not to touch the glass of the new lens during installation in order to avoid damaging it.
  1. Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab. Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
    • Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
  2. Tilt device so that batteries slide out.
    • Tilt device so that batteries slide out.
  3. Apple Watch 套装
    Screen and battery repairs just got easier.
    现在开始购物
    Apple Watch 套装
    现在开始购物
  4. Carefully insert the flat end of the spudger into the seam on the top side of the device.  Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate. Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart.  Take care not to break the plastic hinge as the battery compartment cover is removed. Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart.  Take care not to break the plastic hinge as the battery compartment cover is removed.
    • Carefully insert the flat end of the spudger into the seam on the top side of the device. Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate.
    • Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart. Take care not to break the plastic hinge as the battery compartment cover is removed.
  5. Make sure to take care in prying case apart. There are two wires (one red and one black) that could get disconnected from the motherboard. Gently seperate the two halves of the device. To remove the circuit board from the right section of the device, unscrew the two 5.6 mm Phillips #00 screws.
    • Make sure to take care in prying case apart. There are two wires (one red and one black) that could get disconnected from the motherboard.
    • Gently seperate the two halves of the device.
    • To remove the circuit board from the right section of the device, unscrew the two 5.6 mm Phillips #00 screws.
    • When the screws have been fully unscrewed, use the tweezers to remove them from the device.
  6. Turn the device over so that the lens is facing downward.  Take care not to detach any wires during this step. Locate and unscrew the two 5.6 mm Phillips #00 screws holding the lens to the board. Turn the device back over so that the lens faces upward, and carefully remove the lens from the board.
    • Turn the device over so that the lens is facing downward. Take care not to detach any wires during this step.
    • Locate and unscrew the two 5.6 mm Phillips #00 screws holding the lens to the board.
    • Turn the device back over so that the lens faces upward, and carefully remove the lens from the board.
结论
Katelyn Fry
于2013年03月11日注册
1 信誉积分
创作了7篇指南
团队
Clemson, Team 12-3, Benson Spring 2013 Clemson, Team 12-3, Benson Spring 2013 的会员
CLEM-BENSON-S13S12G3
3 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 118
