跳转到主内容
Jazz Digi-Stix JDC11 Capture Button Replacement
你所需要的
  1. Jazz Digi-Stix JDC11 Capture Button Replacement, Battery: 步骤 1 中的图像 1,2 Jazz Digi-Stix JDC11 Capture Button Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
  2. Jazz Digi-Stix JDC11 Capture Button Replacement: 步骤 2 中的图像 1,1
    • Tilt device so that batteries slide out.
  3. Jazz Digi-Stix JDC11 Capture Button Replacement, Capture Button: 步骤 3 中的图像 1,3 Jazz Digi-Stix JDC11 Capture Button Replacement, Capture Button: 步骤 3 中的图像 2,3 Jazz Digi-Stix JDC11 Capture Button Replacement, Capture Button: 步骤 3 中的图像 3,3
    • Carefully insert the flat end of the spudger into the seam on the top side of the device. Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate.
    • Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart. Take care not to break the plastic hinge as the battery compartment cover is removed.
  4. Jazz Digi-Stix JDC11 Capture Button Replacement: 步骤 4 中的图像 1,3 Jazz Digi-Stix JDC11 Capture Button Replacement: 步骤 4 中的图像 2,3 Jazz Digi-Stix JDC11 Capture Button Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • There are two wires (one red and one black) that could get disconnected from the motherboard when prying the case apart.
    • Gently seperate the two halves of the device.
    • To remove the circuit board from the right section of the device, unscrew the two 5.6 mm Phillips #00 screws.
    • When the screws have been fully unscrewed, use the tweezers to remove them from the device.
  5. Jazz Digi-Stix JDC11 Capture Button Replacement: 步骤 5 中的图像 1,1
    • Carefully separate the grey side bar from the case and set it aside.
  6. Jazz Digi-Stix JDC11 Capture Button Replacement: 步骤 6 中的图像 1,1
    • Use the tweezers to grasp the bottom of the capture button. Pull the capture button away from the case and set it aside.
结论
Katelyn Fry
于03/11/13注册
1 声望
创作了7篇指南
团队
Clemson, Team 12-3, Benson Spring 2013 Clemson, Team 12-3, Benson Spring 2013 的会员
CLEM-BENSON-S13S12G3
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 226
