跳转到主内容
Jawbone MINI JAMBOX Outer Case Replacement
你所需要的
  1. Jawbone MINI JAMBOX Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,2 Jawbone MINI JAMBOX Outer Case Replacement, Outer Case: 步骤 1 中的图像 2,2
    • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
  2. Jawbone MINI JAMBOX Outer Case Replacement: 步骤 2 中的图像 1,1
    • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
    • Carefully remove the end panel.
    • The tabs which connect the panel are on the short sides.
    • WARNING: you will likely cause cosmetic damage to the end cap.
  3. Jawbone MINI JAMBOX Outer Case Replacement: 步骤 3 中的图像 1,1
    • Slide out the rubber foot located on the bottom of the case.
  4. Jawbone MINI JAMBOX Outer Case Replacement: 步骤 4 中的图像 1,1
    • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
    • This is the only flat topped screw in the speaker, so keep track of which one it is.
  5. Jawbone MINI JAMBOX Outer Case Replacement: 步骤 5 中的图像 1,3 Jawbone MINI JAMBOX Outer Case Replacement: 步骤 5 中的图像 2,3 Jawbone MINI JAMBOX Outer Case Replacement: 步骤 5 中的图像 3,3
    • Push against the side without end cap to slide the internal components out of the case.
    • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
    • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
结论
另外一个人完成了本指南。
Noah Sadler
于04/01/15注册
548 声望
创作了2篇指南
团队
Cal Poly, Team 12-1, Lancaster Spring 2015 Cal Poly, Team 12-1, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G1
5 名成员
创作了11篇指南
一条评论
Does anyone know where to find replacement outer shells for the big jambox?
aric.valliere - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 3,242
