跳转到主内容
Jam XT HX-P430 Disassembly
你所需要的
  1. Jam XT HX-P430 Disassembly, Casing: 步骤 1 中的图像 1,1
    • You can really take this off however you want but here's a pic.
  2. Jam XT HX-P430 Disassembly, Speaker Guard: 步骤 2 中的图像 1,3 Jam XT HX-P430 Disassembly, Speaker Guard: 步骤 2 中的图像 2,3 Jam XT HX-P430 Disassembly, Speaker Guard: 步骤 2 中的图像 3,3
    • Using a spudger or similar pry the guard off one side at a time.
  3. Jam XT HX-P430 Disassembly, Screws!: 步骤 3 中的图像 1,2 Jam XT HX-P430 Disassembly, Screws!: 步骤 3 中的图像 2,2
    • Remove the screws for the speaker and the four that are down the holes.
    • It isn't necessary but I removed the d-ring as well.
  4. Jam XT HX-P430 Disassembly, Case: 步骤 4 中的图像 1,3 Jam XT HX-P430 Disassembly, Case: 步骤 4 中的图像 2,3 Jam XT HX-P430 Disassembly, Case: 步骤 4 中的图像 3,3
    • Remove the black button spacers. (Note: There are 3 spacers I lost one).
    • Push the white bottom through the hole and slowly wiggle the blue case off. Be careful not to break the speaker cables.
    • Now remove the four screws.
  5. Jam XT HX-P430 Disassembly, Board and Battery.: 步骤 5 中的图像 1,3 Jam XT HX-P430 Disassembly, Board and Battery.: 步骤 5 中的图像 2,3 Jam XT HX-P430 Disassembly, Board and Battery.: 步骤 5 中的图像 3,3
    • They used black silicone to keep the connectors together so the entire assembly may come off. I suggest making sure you know how the go back together.
    • Carefully using a knife try to split the silicone so the connectors come off easily.
    • Next remove the fours screws holding the board in. (Note: There is two matching pairs.)
    • Using the spudger remove the battery from the white plastic.
  6. Jam XT HX-P430 Disassembly, Finished!: 步骤 6 中的图像 1,2 Jam XT HX-P430 Disassembly, Finished!: 步骤 6 中的图像 2,2
    • Yay! It is disassembled.
    • (Note: There are 3 spacers I lost one).
结论
Wolf Andrew
于03/19/18注册
133 声望
撰写一个指南
1指南评论
Is the amp bridgable ?
jonathan s - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 803
