跳转到主内容
Jam Voice Motherboard Replacement
你所需要的
  1. Jam Voice Motherboard  Replacement, Hard Mesh Cover: 步骤 1 中的图像 1,2 Jam Voice Motherboard  Replacement, Hard Mesh Cover: 步骤 1 中的图像 2,2
    • Insert the plastic opening tool underneath the mesh top.
    • Pry the cover open.
    • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
  2. Jam Voice Motherboard  Replacement, Motherboard: 步骤 2 中的图像 1,1
    • Remove the four 7mm Phillips screws from the plastic cover.
  3. Jam Voice Motherboard  Replacement: 步骤 3 中的图像 1,2 Jam Voice Motherboard  Replacement: 步骤 3 中的图像 2,2
    • Remove the four 5mm Phillips screws that hold down the speaker in place.
    • Remove the two 6mm Phillips screws that hold down the plastic casing.
  4. Jam Voice Motherboard  Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    Halberd Spudger
    $2.99
    购买
    • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
    • Pull the speaker up and out.
  5. Jam Voice Motherboard  Replacement: 步骤 5 中的图像 1,3 Jam Voice Motherboard  Replacement: 步骤 5 中的图像 2,3 Jam Voice Motherboard  Replacement: 步骤 5 中的图像 3,3
    • Remove the four 7mm Phillips screws to expose the motherboard.
  6. Jam Voice Motherboard  Replacement: 步骤 6 中的图像 1,1
    • After removing all of the screws from the plastic cover, remove it by pulling up and out.
    • Be careful not to pull and damage any of the wires.
  7. Jam Voice Motherboard  Replacement: 步骤 7 中的图像 1,2 Jam Voice Motherboard  Replacement: 步骤 7 中的图像 2,2
    • Remove the three 5mm Phillips screws that hold the motherboard in place.
    • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 243
