跳转到主内容
Jalousie Window Gearbox Replacement
你所需要的
  1. Jalousie Window Gearbox Replacement, Gearbox: 步骤 1 中的图像 1,1
    • Before you begin, crank the window open an inch or two.
    • After the crank is removed, you won't be able to open the window for extra room to use your screwdriver in here.
  2. Jalousie Window Gearbox Replacement: 步骤 2 中的图像 1,1
    • To get to the gearbox, you must remove a few parts.
    • Remove the crank handle screw.
  3. Jalousie Window Gearbox Replacement: 步骤 3 中的图像 1,1
    • Remove the crank handle by pulling it straight out.
    • Notice in the picture that the window frame is still in front of the gearbox. You will need to either remove that side of the frame or shift it out of the way.
  4. Jalousie Window Gearbox Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips screwdriver, remove the two screws from the gearbox.
  5. Jalousie Window Gearbox Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips screwdriver, remove the two screws from the mount at the opposite end of the bar.
  6. Jalousie Window Gearbox Replacement: 步骤 6 中的图像 1,1
    • Lift the bar up slightly so that it pivots and the gearbox will roll about 30 degrees back.
    • This allows you to clear the lower window frame and pull the bar clear of it.
    • Angle the bar as you're bringing it forward so that the gearbox clears the frame first, then the mount side can be brought forward too.
  7. Jalousie Window Gearbox Replacement: 步骤 7 中的图像 1,1
    • Pry the gearbox from the end of the bar using a flat head screwdriver.
    • If it seems stuck, work the screwdriver around the gap gently. You don't want to bend anything.
  8. Jalousie Window Gearbox Replacement: 步骤 8 中的图像 1,1
    • Place the new gearbox onto the end of the bar. Be sure to line up the slots in the bar with the two ridges inside the sleeve of the gearbox.
    • You do not need to remove the mount on the other end unless it is broken and also needs to be replaced. Both of these parts need to be securely fastened to the window box for the window to work.
  9. Jalousie Window Gearbox Replacement: 步骤 9 中的图像 1,1
    • With the new gearbox in place, angle the bar back into place with the mount end going in first. .
    • Keep the bar slightly rotated so that the gearbox will clear the window frame.
    • The gearbox angle you see in the picture is important.
  10. Jalousie Window Gearbox Replacement: 步骤 10 中的图像 1,1
    • Swing the gearbox and the mount into their original positions, matching the screw holes is a good reference.
    • Reinstall the screws in the gearbox and mount.
  11. Jalousie Window Gearbox Replacement: 步骤 11 中的图像 1,1
    • After you have screwed the gearbox and mount into place, test the gearbox with the crank to be sure it opens and closes.
    • If everything functions well, put your frame and crank handle back on.
结论
Mission accomplished!
6等其他人完成本指南。
Jewells1
于01/16/18注册
400 声望
撰写一个指南
团队
13条评论
thank you , so simple and effective
tehillimsong - 回复
thank you so much for taking the time to share your knowledge and experience in this DIY project. I have several windows like this I need to fix.
Cecilia Andrus - 回复
Thanks for this. One of mine seems to have stripped out. Opens fully, but won’t pull the window fully closed. I’ll replace the gear box.
Mic - 回复
Where do you buy the gear boxes from?
dixietraders4 - 回复
Ace hardware they have all kinds
Paul Busby -
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 43
过去 30 天: 201
总计 13,697
