跳转到主内容
Jabra Freeway Speaker Replacement
你所需要的
  1. Jabra Freeway Speaker Replacement, Front Panel: 步骤 1 中的图像 1,3 Jabra Freeway Speaker Replacement, Front Panel: 步骤 1 中的图像 2,3 Jabra Freeway Speaker Replacement, Front Panel: 步骤 1 中的图像 3,3
    • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
    • Remove the rubber pads from the bottom of the device using the spudger.
  2. Jabra Freeway Speaker Replacement: 步骤 2 中的图像 1,3 Jabra Freeway Speaker Replacement: 步骤 2 中的图像 2,3 Jabra Freeway Speaker Replacement: 步骤 2 中的图像 3,3
    • Remove the eight 6mm T9 screws.
    • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
  3. Jabra Freeway Speaker Replacement: 步骤 3 中的图像 1,3 Jabra Freeway Speaker Replacement: 步骤 3 中的图像 2,3 Jabra Freeway Speaker Replacement: 步骤 3 中的图像 3,3
    • Gently lift the front panel off of the device and carefully rest it to the side.
  4. Jabra Freeway Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 Jabra Freeway Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    • Gently lift the speaker out of the device using the spudger.
    • The speaker is not fixed in place, and therefore very little force is necessary to remove this component.
  5. Jabra Freeway Speaker Replacement: 步骤 5 中的图像 1,1
    • Desolder the two wires connecting to the speaker.
结论
另外一个人完成了本指南。
Alec Wilson
于10/19/16注册
741 声望
创作了5篇指南
团队
UMass Dartmouth, Team 4-8, Catania Fall 2016 UMass Dartmouth, Team 4-8, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G8
2 名成员
创作了6篇指南
一条评论
This guide is missing something. It is titled Speaker Replacement not just removal. Useful information to complete the replacement of a faulty speaker would include where to find a replacement part or at least a part number to search for. Removing the speaker without replacing it with another is of little use. But thank you for your time and effort.
Jssamp - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 966
