跳转到主内容
Jabra Elite 85h Speaker Replacement
你所需要的
  1. Jabra Elite 85h Speaker Replacement, Ear Cushion: 步骤 1 中的图像 1,3 Jabra Elite 85h Speaker Replacement, Ear Cushion: 步骤 1 中的图像 2,3 Jabra Elite 85h Speaker Replacement, Ear Cushion: 步骤 1 中的图像 3,3
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
  2. Jabra Elite 85h Speaker Replacement, Speaker: 步骤 2 中的图像 1,3 Jabra Elite 85h Speaker Replacement, Speaker: 步骤 2 中的图像 2,3 Jabra Elite 85h Speaker Replacement, Speaker: 步骤 2 中的图像 3,3
    • The foam inserts and backing tape are very delicate. Take your time when removing them, and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
  3. Jabra Elite 85h Speaker Replacement: 步骤 3 中的图像 1,3 Jabra Elite 85h Speaker Replacement: 步骤 3 中的图像 2,3 Jabra Elite 85h Speaker Replacement: 步骤 3 中的图像 3,3
    • Repeat the previous steps for the other side, removing the foam inserts with care.
  4. Jabra Elite 85h Speaker Replacement: 步骤 4 中的图像 1,1
    • Unscrew and remove the four T6 screws holding the speaker in place.
  5. Jabra Elite 85h Speaker Replacement: 步骤 5 中的图像 1,1
    • Repeat the previous step for the other side, removing the four T6 screws.
  6. Jabra Elite 85h Speaker Replacement: 步骤 6 中的图像 1,1
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
结论
2等其他人完成本指南。
Matt Gardiner
于03/15/23注册
324 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-4, Petersen Spring 2023 UMass Dartmouth, Team 3-4, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S3G4
4 名成员
创作了9篇指南
3条评论
Thanks a lot man, I was having some issues with my left side for a while. I assumed it was bad connection since it would return depending on the position and sometimes on non-ANC setup. I just tightened those screws and now it works fine. Cheers.
Alex Fernandes - 回复
Hi, doughter overturned the speaker. Now the device no longer switches on. can this be fixed again?
Thanks fit your Help.
Regards
Oliver Viboh - 回复
Where can I get replacement speakers. I know it is 40mm in diameter but what is the ohm and other specifications?
Çağdaş Son - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 70
总计 1,093
