跳转到主内容
Jabra Elite 85h Microphone Replacement
你所需要的
  1. Jabra Elite 85h Microphone Replacement, Ear Cushion: 步骤 1 中的图像 1,3 Jabra Elite 85h Microphone Replacement, Ear Cushion: 步骤 1 中的图像 2,3 Jabra Elite 85h Microphone Replacement, Ear Cushion: 步骤 1 中的图像 3,3
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
  2. Jabra Elite 85h Microphone Replacement, Speaker: 步骤 2 中的图像 1,3 Jabra Elite 85h Microphone Replacement, Speaker: 步骤 2 中的图像 2,3 Jabra Elite 85h Microphone Replacement, Speaker: 步骤 2 中的图像 3,3
    • The foam inserts and backing tape are very delicate. Take your time when removing them, and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
  3. Jabra Elite 85h Microphone Replacement: 步骤 3 中的图像 1,3 Jabra Elite 85h Microphone Replacement: 步骤 3 中的图像 2,3 Jabra Elite 85h Microphone Replacement: 步骤 3 中的图像 3,3
    • Repeat the previous steps for the other side, removing the foam inserts with care.
  4. Jabra Elite 85h Microphone Replacement: 步骤 4 中的图像 1,1
    • Unscrew and remove the four T6 screws holding the speaker in place.
  5. Jabra Elite 85h Microphone Replacement: 步骤 5 中的图像 1,1
    • Repeat the previous step for the other side, removing the four T6 screws.
  6. Jabra Elite 85h Microphone Replacement: 步骤 6 中的图像 1,1
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
  7. Jabra Elite 85h Microphone Replacement, Microphone: 步骤 7 中的图像 1,2 Jabra Elite 85h Microphone Replacement, Microphone: 步骤 7 中的图像 2,2
    • Remove the four screws attaching the circuit boards to the headphone enclosure.
    • The microphone is located on the lower circuit board.
  8. Jabra Elite 85h Microphone Replacement: 步骤 8 中的图像 1,3 Jabra Elite 85h Microphone Replacement: 步骤 8 中的图像 2,3 Jabra Elite 85h Microphone Replacement: 步骤 8 中的图像 3,3
    • Remove the circuit boards from the headphone enclosure.
    • Carefully lift the bar located on the lower circuit board that contains the 24-pin ribbon cable. Remove the cable.
结论
If the microphone on your Jabra Elite 85h is not working, replacement could be an appropriate solution.
Ryan Callaghan
于03/13/23注册
725 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-4, Petersen Spring 2023 UMass Dartmouth, Team 3-4, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S3G4
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 40
总计 701
