跳转到主内容
Jabra Elite 85h Battery Replacement
你所需要的
  1. Jabra Elite 85h Battery Replacement, Ear Cushion: 步骤 1 中的图像 1,3 Jabra Elite 85h Battery Replacement, Ear Cushion: 步骤 1 中的图像 2,3 Jabra Elite 85h Battery Replacement, Ear Cushion: 步骤 1 中的图像 3,3
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
  2. Jabra Elite 85h Battery Replacement, Speaker: 步骤 2 中的图像 1,3 Jabra Elite 85h Battery Replacement, Speaker: 步骤 2 中的图像 2,3 Jabra Elite 85h Battery Replacement, Speaker: 步骤 2 中的图像 3,3
    • The foam inserts and backing tape are very delicate. Take your time when removing them, and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
  3. Jabra Elite 85h Battery Replacement: 步骤 3 中的图像 1,3 Jabra Elite 85h Battery Replacement: 步骤 3 中的图像 2,3 Jabra Elite 85h Battery Replacement: 步骤 3 中的图像 3,3
    • Repeat the previous steps for the other side, removing the foam inserts with care.
  4. Jabra Elite 85h Battery Replacement: 步骤 4 中的图像 1,1
    • Unscrew and remove the four T6 screws holding the speaker in place.
  5. Jabra Elite 85h Battery Replacement: 步骤 5 中的图像 1,1
    • Repeat the previous step for the other side, removing the four T6 screws.
  6. Jabra Elite 85h Battery Replacement: 步骤 6 中的图像 1,1
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
  7. Jabra Elite 85h Battery Replacement, Battery: 步骤 7 中的图像 1,1
    • Remove the plastic speaker housing from the left ear of the headphones. This should reveal the battery and motherboard.
  8. Jabra Elite 85h Battery Replacement: 步骤 8 中的图像 1,2 Jabra Elite 85h Battery Replacement: 步骤 8 中的图像 2,2
    • Using a plastic spudger, release the enclosure from the headband.
  9. Jabra Elite 85h Battery Replacement: 步骤 9 中的图像 1,2 Jabra Elite 85h Battery Replacement: 步骤 9 中的图像 2,2
    • Unscrew the two screws holding the motherboard in place and remove the motherboard from the enclosure.
  10. Jabra Elite 85h Battery Replacement: 步骤 10 中的图像 1,3 Jabra Elite 85h Battery Replacement: 步骤 10 中的图像 2,3 Jabra Elite 85h Battery Replacement: 步骤 10 中的图像 3,3
    • Flip the motherboard to reveal a 2-pin JST connector. Carefully unplug the connector from the motherboard and use a plastic spudger to remove the battery from the enclosure.
结论
11等其他人完成本指南。
Ryan Callaghan
于03/13/23注册
693 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-4, Petersen Spring 2023 UMass Dartmouth, Team 3-4, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S3G4
4 名成员
创作了9篇指南
7条评论
Where do you find a battery to match the connector size?
Karl Schantz - 回复
Thanks, I have the Evolve 2 85h, which is similar and this helped me fix it.
I wish to add that my headset refused to charge at all, due to the battery voltage going to low and then the headset did not manage to trickle charge it to a safe charging level. Thus it was dead and Jabra would not repair or replace it claiming the warranty had passed.
By applying 3.8 volts (and limiting it to 300mA) on a test pin connected to the battery + pole for a split second, the charger was tricked into accepting the battery and started charging. Now everything works fine.
Photo of were to apply the voltage. Plus is red. Ground is black.
Some notes -
How it started - I got a battery low warning while listening on a video conference. I attached a USB-C charger cable while wearing the headset. After about 30 minutes the headset just died.
When connecting to a computer, the Jabra App recognized the headset, but said 0% battery. No charging and no Bluetooth communication was possible.
Anders Hedberg - 回复
Does it has 2 batteries? One on left and one on right?
Poon - 回复
I also would like to know how to find a battery that matches the size, or at least gets close enough. Unfortunately just by looking up "3.7v Rechargeable Lithium Polymer Battery" I am finding quite the wide variety of shapes and sizes...
Axe_Metaphor - 回复
On the Battery is a code 553436 which is the form factor of 55mm x 34mm x 36mm. A quick google search couldnt find one suitable for the jabra, the guide speaks about a 2 pin jst but you need a 3 pin battery.
Jeremy Seipelt -
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 87
过去 30 天: 473
总计 5,470
