当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
Gently remove the front panel from the steel enclosure.
Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
Be careful not to scratch or damage components or features of the circuit board with the metal spudger
Remove seven 1/64 x 3/16" screws from the top panel using the Phillips #0 screwdriver.
Remove the top panel.
Disconnect Video Out/Rear View Camera cable from circuit board.
Remove the Video Out/Rear View Camera cable retaining clip using after removing 0-64 x 3/16" machine screw using a Phillips #0 screwdriver.
Withdraw Video Out/Rear View Camera cable from rear panel.
Remove the five 1/64 x 3/16" machine screws from the rear panel identified in the photograph.
Remove rear panel.
取消:我没有完成这个指南。
与3其他贡献者
于09/27/18注册
211 声望
创作了2篇指南
徽章: 4
+1个徽章
LBCC-JOHNSON-F18S1G6
3 名成员
创作了8篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 11
总计 361
