跳转到主内容
JVC KW-V820BT Front Panel Assembly Replacement
你所需要的
  1. JVC KW-V820BT Front Panel Assembly Replacement, Front Panel Assembly: 步骤 1 中的图像 1,3 JVC KW-V820BT Front Panel Assembly Replacement, Front Panel Assembly: 步骤 1 中的图像 2,3 JVC KW-V820BT Front Panel Assembly Replacement, Front Panel Assembly: 步骤 1 中的图像 3,3
    • Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
  2. JVC KW-V820BT Front Panel Assembly Replacement: 步骤 2 中的图像 1,2 JVC KW-V820BT Front Panel Assembly Replacement: 步骤 2 中的图像 2,2
    • Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
  3. JVC KW-V820BT Front Panel Assembly Replacement: 步骤 3 中的图像 1,3 JVC KW-V820BT Front Panel Assembly Replacement: 步骤 3 中的图像 2,3 JVC KW-V820BT Front Panel Assembly Replacement: 步骤 3 中的图像 3,3
    • Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
  4. JVC KW-V820BT Front Panel Assembly Replacement: 步骤 4 中的图像 1,1
    • Gently remove the front panel from the steel enclosure.
  5. JVC KW-V820BT Front Panel Assembly Replacement: 步骤 5 中的图像 1,3 JVC KW-V820BT Front Panel Assembly Replacement: 步骤 5 中的图像 2,3 JVC KW-V820BT Front Panel Assembly Replacement: 步骤 5 中的图像 3,3
    • Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
    • Be careful not to scratch or damage components or features of the circuit board with the metal spudger
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 22
总计 617
