跳转到主内容
JVC KW-V820BT Driver Side Panel Removal and Replacement
你所需要的
  1. JVC KW-V820BT Driver Side Panel Removal and Replacement, Front Panel Assembly: 步骤 1 中的图像 1,3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Front Panel Assembly: 步骤 1 中的图像 2,3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Front Panel Assembly: 步骤 1 中的图像 3,3
    • Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
  2. JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 2 中的图像 1,2 JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 2 中的图像 2,2
    • Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
  3. JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 3 中的图像 1,3 JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 3 中的图像 2,3 JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 3 中的图像 3,3
    • Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
  4. JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 4 中的图像 1,1
    • Gently remove the front panel from the steel enclosure.
  5. JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 5 中的图像 1,3 JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 5 中的图像 2,3 JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 5 中的图像 3,3
    • Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
    • Be careful not to scratch or damage components or features of the circuit board with the metal spudger
  6. JVC KW-V820BT Driver Side Panel Removal and Replacement, Top Panel Removal: 步骤 6 中的图像 1,3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Top Panel Removal: 步骤 6 中的图像 2,3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Top Panel Removal: 步骤 6 中的图像 3,3
    • Remove seven 1/64 x 3/16" screws from the top panel using the Phillips #0 screwdriver.
    • Remove the top panel.
  7. JVC KW-V820BT Driver Side Panel Removal and Replacement, Disc Drive: 步骤 7 中的图像 1,1
    • After removing all screws and top panel, lift up disc drive from steel enclosure.
  8. JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 8 中的图像 1,1
    • Turn over the disc drive to expose the connector.
    • Gently remove the ribbon cable from the ZIF on the circuit board using the metal spudger.
  9. JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 9 中的图像 1,3 JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 9 中的图像 2,3 JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 9 中的图像 3,3
    • Gently pull to remove the electrical connector from disc drive.
  10. JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 10 中的图像 1,2 JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 10 中的图像 2,2
    • Remove 2 pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver.
  11. JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 11 中的图像 1,2 JVC KW-V820BT Driver Side Panel Removal and Replacement: 步骤 11 中的图像 2,2
  12. JVC KW-V820BT Driver Side Panel Removal and Replacement, Driver Side Panel Removal and: 步骤 12 中的图像 1,3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Driver Side Panel Removal and: 步骤 12 中的图像 2,3 JVC KW-V820BT Driver Side Panel Removal and Replacement, Driver Side Panel Removal and: 步骤 12 中的图像 3,3
    • Remove the six pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 207
