跳转到主内容
JVC KW-V820BT Cooling Fan Removal and Replacement
你所需要的
  1. JVC KW-V820BT Cooling Fan Removal and Replacement, Front Panel Assembly: 步骤 1 中的图像 1,3 JVC KW-V820BT Cooling Fan Removal and Replacement, Front Panel Assembly: 步骤 1 中的图像 2,3 JVC KW-V820BT Cooling Fan Removal and Replacement, Front Panel Assembly: 步骤 1 中的图像 3,3
    • Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
  2. JVC KW-V820BT Cooling Fan Removal and Replacement: 步骤 2 中的图像 1,2 JVC KW-V820BT Cooling Fan Removal and Replacement: 步骤 2 中的图像 2,2
    • Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
  3. JVC KW-V820BT Cooling Fan Removal and Replacement: 步骤 3 中的图像 1,3 JVC KW-V820BT Cooling Fan Removal and Replacement: 步骤 3 中的图像 2,3 JVC KW-V820BT Cooling Fan Removal and Replacement: 步骤 3 中的图像 3,3
    • Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
  4. JVC KW-V820BT Cooling Fan Removal and Replacement: 步骤 4 中的图像 1,1
    • Gently remove the front panel from the steel enclosure.
  5. JVC KW-V820BT Cooling Fan Removal and Replacement: 步骤 5 中的图像 1,3 JVC KW-V820BT Cooling Fan Removal and Replacement: 步骤 5 中的图像 2,3 JVC KW-V820BT Cooling Fan Removal and Replacement: 步骤 5 中的图像 3,3
    • Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
    • Be careful not to scratch or damage components or features of the circuit board with the metal spudger
  6. JVC KW-V820BT Cooling Fan Removal and Replacement, Top Panel Removal: 步骤 6 中的图像 1,3 JVC KW-V820BT Cooling Fan Removal and Replacement, Top Panel Removal: 步骤 6 中的图像 2,3 JVC KW-V820BT Cooling Fan Removal and Replacement, Top Panel Removal: 步骤 6 中的图像 3,3
    • Remove seven 1/64 x 3/16" screws from the top panel using the Phillips #0 screwdriver.
    • Remove the top panel.
  7. JVC KW-V820BT Cooling Fan Removal and Replacement, Rear Panel Removal and Replacement: 步骤 7 中的图像 1,3 JVC KW-V820BT Cooling Fan Removal and Replacement, Rear Panel Removal and Replacement: 步骤 7 中的图像 2,3 JVC KW-V820BT Cooling Fan Removal and Replacement, Rear Panel Removal and Replacement: 步骤 7 中的图像 3,3
    • Disconnect Video Out/Rear View Camera cable from circuit board.
    • Remove the Video Out/Rear View Camera cable retaining clip using after removing 0-64 x 3/16" machine screw using a Phillips #0 screwdriver.
    • Withdraw Video Out/Rear View Camera cable from rear panel.
  8. JVC KW-V820BT Cooling Fan Removal and Replacement: 步骤 8 中的图像 1,3 JVC KW-V820BT Cooling Fan Removal and Replacement: 步骤 8 中的图像 2,3 JVC KW-V820BT Cooling Fan Removal and Replacement: 步骤 8 中的图像 3,3
    • Remove the five 1/64 x 3/16" machine screws from the rear panel identified in the photograph.
    • Remove rear panel.
  9. JVC KW-V820BT Cooling Fan Removal and Replacement, Cooling Fan: 步骤 9 中的图像 1,3 JVC KW-V820BT Cooling Fan Removal and Replacement, Cooling Fan: 步骤 9 中的图像 2,3 JVC KW-V820BT Cooling Fan Removal and Replacement, Cooling Fan: 步骤 9 中的图像 3,3
    • Remove the two 1-64 x 1/2" machine screws and the retaining nuts that fasten the cooling fan to the rear panel using the Phillips #0 screwdriver and the 5/32" socket.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 322
