跳转到主内容
JVC GR-D72U LED Light Replacement
你所需要的
  1. JVC GR-D72U LED Light Replacement, Battery: 步骤 1 中的图像 1,2 JVC GR-D72U LED Light Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate button on bottom of camera.
    • Slide button to the right.
  2. JVC GR-D72U LED Light Replacement: 步骤 2 中的图像 1,1
    • Pull the battery towards the bottom of the camcorder while lifting battery .
  3. JVC GR-D72U LED Light Replacement, Lateral Function Port Panel: 步骤 3 中的图像 1,3 JVC GR-D72U LED Light Replacement, Lateral Function Port Panel: 步骤 3 中的图像 2,3 JVC GR-D72U LED Light Replacement, Lateral Function Port Panel: 步骤 3 中的图像 3,3
    • Remove silver plate that says “Auto Light” on the top of the camera using a metal spudger.
    • Remove the 3.1 mm screw.
    • Remove the three 5.3 mm screws from the back of the camera.
  4. JVC GR-D72U LED Light Replacement: 步骤 4 中的图像 1,1
    • From the bottom of the camera remove the following four screws:
    • 5.3 mm
    • 3.1 mm
    • 5.1 mm
    • 3.5 mm
  5. JVC GR-D72U LED Light Replacement: 步骤 5 中的图像 1,1
    • Use the small plastic opening tool to remove the blue side cover piece.
  6. JVC GR-D72U LED Light Replacement: 步骤 6 中的图像 1,1
    • Remove the 3.1 mm screw on top of the camera, closest to the LCD monitor.
    • Remove the 5.4 mm screw next to the snapshot button.
  7. JVC GR-D72U LED Light Replacement: 步骤 7 中的图像 1,1
    • Remove the 3.1 mm screw next to the USB and DV inputs.
  8. JVC GR-D72U LED Light Replacement: 步骤 8 中的图像 1,1
    • Gently pull apart both halves of the camera to reveal the inner components.
  9. JVC GR-D72U LED Light Replacement: 步骤 9 中的图像 1,3 JVC GR-D72U LED Light Replacement: 步骤 9 中的图像 2,3 JVC GR-D72U LED Light Replacement: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Flip the cable locks to the up-position and pull both cables connecting the lateral function port panel to the rest of the camera.
    • Insert the cables from the new port panel into their inputs and flip the locks to the down position.
    • It is easier to use tweezers when inserting the cable but not required.
  10. JVC GR-D72U LED Light Replacement, Cassette Holder: 步骤 10 中的图像 1,1
    • From the inside of the camera remove these six screws.
    • 3.3 mm
    • 3.6 mm
    • 3.1 mm
    • 4.3 mm
    • 4.3 mm
    • 3.7 mm
  11. JVC GR-D72U LED Light Replacement: 步骤 11 中的图像 1,1
    • Unplug the three cables from the circuit board.
  12. JVC GR-D72U LED Light Replacement: 步骤 12 中的图像 1,3 JVC GR-D72U LED Light Replacement: 步骤 12 中的图像 2,3 JVC GR-D72U LED Light Replacement: 步骤 12 中的图像 3,3
    • From the top of the camera remove the two 3.1 mm screws securing the lens to the camera frame.
    • From the bottom of the camera remove the 3.2 mm screw next to the battery release switch.
    • Remove the 9.1 mm screw next to the menu and volume control label.
  13. JVC GR-D72U LED Light Replacement: 步骤 13 中的图像 1,2 JVC GR-D72U LED Light Replacement: 步骤 13 中的图像 2,2
    • Remove the lens cap housing.
    • Remove the two 3.1 mm screws from the inside of the camera.
  14. JVC GR-D72U LED Light Replacement: 步骤 14 中的图像 1,3 JVC GR-D72U LED Light Replacement: 步骤 14 中的图像 2,3 JVC GR-D72U LED Light Replacement: 步骤 14 中的图像 3,3
    • Remove the plastic cover piece next to the silver light button.
    • Remove the 3.1 mm screw securing the lens to the circuit board.
    • Remove the two 3.3 mm screws from underneath the battery port.
  15. JVC GR-D72U LED Light Replacement: 步骤 15 中的图像 1,2 JVC GR-D72U LED Light Replacement: 步骤 15 中的图像 2,2
    • Take the cassette holder and circuit board by lifting it out of the camera frame.
    • Remove the two 3.6 mm screws.
    • Remove the two 1.8 mm screws then the plate.
    • If you are following this guide to replace the LED light or microphone you do not need to follow this step or the next step.
  16. JVC GR-D72U LED Light Replacement: 步骤 16 中的图像 1,3 JVC GR-D72U LED Light Replacement: 步骤 16 中的图像 2,3 JVC GR-D72U LED Light Replacement: 步骤 16 中的图像 3,3
    • Remove the six cables (one is underneath the metal plate) connecting the cassette holder to the circuit board.
    • To unplug two of the cables you must first pull the lock tabs out (towards the cable) then remove the cable.
  17. JVC GR-D72U LED Light Replacement, LED Light: 步骤 17 中的图像 1,1
    • Remove the three screws securing the microphone housing and camera operation buttons to the frame with the following sizes:
    • 4.3 mm
    • 3.1 mm
    • 4.2 mm
  18. JVC GR-D72U LED Light Replacement: 步骤 18 中的图像 1,2 JVC GR-D72U LED Light Replacement: 步骤 18 中的图像 2,2
    • Remove the 4.3 mm screw on the bottom of the camera frame.
    • Remove the two 4.3 mm screws above the LED securing the microphone housing to the frame.
  19. JVC GR-D72U LED Light Replacement: 步骤 19 中的图像 1,3 JVC GR-D72U LED Light Replacement: 步骤 19 中的图像 2,3 JVC GR-D72U LED Light Replacement: 步骤 19 中的图像 3,3
    • Open the cassette holder to reveal a 2.4 mm screw on the bottom of the camera and remove it.
    • Make sure the camera operation buttons are positioned completely outside of the camera frame.
    • Gently lift the microphone housing from the front-bottom side of the camera and remove it from the frame.
  20. JVC GR-D72U LED Light Replacement: 步骤 20 中的图像 1,2 JVC GR-D72U LED Light Replacement: 步骤 20 中的图像 2,2
    • Remove the two 2.3 mm screws holding down the LED chip and remove the chip.
    • Ignore this step if you are following this guide for the microphone.
结论
另外一个人完成了本指南。
Jonah Powers
于09/28/17注册
437 声望
创作了4篇指南
团队
USF Tampa, Team S2-G2, Nance Fall 2017 USF Tampa, Team S2-G2, Nance Fall 2017 的会员
USFT-NANCE-F17S2G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 220
