简介
If the power or record button isn't working on your JVC Adixxion GC-XA1BU, follow the instructions to replace the board. To complete this guide, you will need to purchase a new power/record button board and make sure that you have the tools listed. It is always good practice to make sure that the device is completely powered off and remove the battery before attempting any repairs.
你所需要的
After removing the battery, take out the two Phillips screws (4mm headsize x 3mm length) screws. You can now remove the battery cover.
Using a 1x1xH1.5 torx screwdriver, remove the 8 screws (5mm headsize / 4mm length) from the corners of both the front and back of the camera (4 screws on each side).
Carefully peel off the glue holding the red and black braided wire down to the circuit board. Then remove the connector by gently pulling it out of its casing. You will want to save this glue as it may come in handy when re-assembling your device.
The power and record buttons are glued to the battery housing, so use the plastic opening tool to gently pry off and remove the buttons.
另外一个人完成了本指南。
