简介
To complete this guide, you will need to purchase a new LCD cover and make sure that you have the tools listed. It is always good practice to make sure that the device is completely powered off and remove the battery before attempting any repairs.
你所需要的
Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
Remove the 8 screws (5mm x 4mm) from the corners of both the front and back of the camera (4 screws on each side) using the T6 Torx screwdriver.
另外一个人完成了本指南。
