跳转到主内容
JVC Adixxion GC-XA1BU LCD Cover Replacement
你所需要的
  1. JVC Adixxion GC-XA1BU LCD Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Find the side of the camera with the black switch shown.
  2. JVC Adixxion GC-XA1BU LCD Cover Replacement: 步骤 2 中的图像 1,1
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU LCD Cover Replacement: 步骤 3 中的图像 1,1
    • Slide the battery cover back while pushing down on the black switch.
  4. JVC Adixxion GC-XA1BU LCD Cover Replacement: 步骤 4 中的图像 1,2 JVC Adixxion GC-XA1BU LCD Cover Replacement: 步骤 4 中的图像 2,2
    • Open the battery compartment and push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU LCD Cover Replacement: 步骤 5 中的图像 1,1
    • Remove the battery from the camera.
  6. JVC Adixxion GC-XA1BU LCD Cover Replacement, Battery Cover: 步骤 6 中的图像 1,1
    • Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
  7. JVC Adixxion GC-XA1BU LCD Cover Replacement, LCD Cover: 步骤 7 中的图像 1,2 JVC Adixxion GC-XA1BU LCD Cover Replacement, LCD Cover: 步骤 7 中的图像 2,2
    • Remove the 8 screws (5mm x 4mm) from the corners of both the front and back of the camera (4 screws on each side) using the T6 Torx screwdriver.
  8. JVC Adixxion GC-XA1BU LCD Cover Replacement: 步骤 8 中的图像 1,1
    • Carefully open the camera as shown and gently peel off the black cover tape.
  9. JVC Adixxion GC-XA1BU LCD Cover Replacement: 步骤 9 中的图像 1,3 JVC Adixxion GC-XA1BU LCD Cover Replacement: 步骤 9 中的图像 2,3 JVC Adixxion GC-XA1BU LCD Cover Replacement: 步骤 9 中的图像 3,3
    • Carefully lift up and remove the cable ribbon clip using the tweezers.
  10. JVC Adixxion GC-XA1BU LCD Cover Replacement: 步骤 10 中的图像 1,2 JVC Adixxion GC-XA1BU LCD Cover Replacement: 步骤 10 中的图像 2,2
    • Carefully grasp and remove the ribbon cable using the tweezers.
  11. JVC Adixxion GC-XA1BU LCD Cover Replacement: 步骤 11 中的图像 1,1
    • Turn the camera as shown and carefully remove the glue from the connector.
  12. JVC Adixxion GC-XA1BU LCD Cover Replacement: 步骤 12 中的图像 1,2 JVC Adixxion GC-XA1BU LCD Cover Replacement: 步骤 12 中的图像 2,2
    • Carefully pull the white clip out of the casing using the tweezers.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 1-2, Tanski Winter 2015 USF Tampa, Team 1-2, Tanski Winter 2015 的会员
USFT-TANSKI-W15S1G2
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 476
