跳转到主内容
加入维修社区 - 创建账户
JLab Pro-7 Wireless Antenna Replacement
你所需要的
  1. JLab Pro-7 Wireless Antenna Replacement, JLab Pro-7 Disassembly: 步骤 1 中的图像 1,1
    • The tools needed in order to complete this task are above in the tools section.
    • Grab your tablet and have your tools ready in order to open it and fix the components inside.
    询问修复机器人
    添加评论
  2. JLab Pro-7 Wireless Antenna Replacement: 步骤 2 中的图像 1,1
    • At the bottom of the tablet there are two screws.
    • One screw is on the bottom left corner and the other is in the bottom right corner.
    • Here, you need to grab a small Phillips screwdriver and carefully take out these screws. Be careful not to strip the screws when taking them out.
    询问修复机器人
    添加评论
  3. JLab Pro-7 Wireless Antenna Replacement: 步骤 3 中的图像 1,1
    • Now grab your iFixit prying tool and try to carefully pry off the back casing.
    • The back doesn't want to dislodge easily so make sure the end of your pry tool is underneath the screen in order to get enough leverage to start popping off the back case from the screen.
    • Be careful when prying the edge of your tablet! Avoid snapping the volume and lock buttons. Also try not to dig into the tablet too deep with your prying tool so you don't damage any components inside.
    询问修复机器人
    添加评论
  4. JLab Pro-7 Wireless Antenna Replacement: 步骤 4 中的图像 1,1
    • Make sure to make your way around the perimeter of the tablet in order to take off the back casing.
    • Put small amounts of pressure around the perimeter until you see that section pop off.
    • Keep moving your way clockwise or counterclockwise until the back is fully removed.
    询问修复机器人
    添加评论
  5. JLab Pro-7 Wireless Antenna Replacement: 步骤 5 中的图像 1,1
    • There you have it now the back should be fully removed.
    • Make sure to inspect your tablet for any damage from prying off the back panel of your panel.
    • If any internals did fall out or seem to be damaged check out our guides we may be able to help you!
    询问修复机器人
    添加评论
  6. JLab Pro-7 Wireless Antenna Replacement, Wireless Antenna: 步骤 6 中的图像 1,2 JLab Pro-7 Wireless Antenna Replacement, Wireless Antenna: 步骤 6 中的图像 2,2
    • Locate antenna end above battery
    • The antenna will be located next to the plastic fixture for the speaker
    • Antenna will wrap around the side of the battery and lead to the motherboard
    询问修复机器人
    添加评论
  7. JLab Pro-7 Wireless Antenna Replacement: 步骤 7 中的图像 1,1
    • Locate the strip of black thermal tape holding antenna to the back of the tablet
    • Strip of tape will be over both the antenna, and the edge of the battery
    • Carefully remove the strip of tape and set it aside for reassembly later
    询问修复机器人
    添加评论
  8. JLab Pro-7 Wireless Antenna Replacement: 步骤 8 中的图像 1,2 JLab Pro-7 Wireless Antenna Replacement: 步骤 8 中的图像 2,2
    • Follow length of antenna to the point on the motherboard that it's sautered to
    • Use a sautering iron to remove the sauters on the motherboard
    • Carefully remove the antenna
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
RichardCollette
于03/05/17注册
201 声望
创作了2篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 311
