跳转到主内容
加入维修社区 - 创建账户
JIAYU F1 Volume Button Replacement
你所需要的
  1. JIAYU F1 Volume Button Replacement, Turn Off the Phone: 步骤 1 中的图像 1,1
    • Turn the phone off by holding down the power button located on the top of the phone.
  2. JIAYU F1 Volume Button Replacement, Remove the Back Case: 步骤 2 中的图像 1,3 JIAYU F1 Volume Button Replacement, Remove the Back Case: 步骤 2 中的图像 2,3 JIAYU F1 Volume Button Replacement, Remove the Back Case: 步骤 2 中的图像 3,3
    • Find the small indentation at the bottom right of the phone and pry open the back case of the phone using your fingernail or small plastic opening tool.
    • Gently remove the back case completely from the phone.
  3. JIAYU F1 Volume Button Replacement, Remove the Battery: 步骤 3 中的图像 1,3 JIAYU F1 Volume Button Replacement, Remove the Battery: 步骤 3 中的图像 2,3 JIAYU F1 Volume Button Replacement, Remove the Battery: 步骤 3 中的图像 3,3
    • Insert a fingernail or the small plastic opening tool into the recess in the bottom center of the battery and lift upward.
    • Remove the battery from the phone.
    • When replacing the battery, align the copper ports on the top right of the battery with the corresponding ports in the battery cavity.
  4. JIAYU F1 Volume Button Replacement, Remove the Interior Midframe Assembly: 步骤 4 中的图像 1,3 JIAYU F1 Volume Button Replacement, Remove the Interior Midframe Assembly: 步骤 4 中的图像 2,3 JIAYU F1 Volume Button Replacement, Remove the Interior Midframe Assembly: 步骤 4 中的图像 3,3
    • With the phone lying face down, remove the nine 3 mm Phillips # 00 screws from the midframe.
    • Gently run a plastic opening tool down along the left and right sides of the phone to separate the black midframe assembly from the silver display casing.
    • Carefully remove the midframe assembly from the display casing by pulling up and away from the phone.
  5. JIAYU F1 Volume Button Replacement, Remove Volume Button: 步骤 5 中的图像 1,3 JIAYU F1 Volume Button Replacement, Remove Volume Button: 步骤 5 中的图像 2,3 JIAYU F1 Volume Button Replacement, Remove Volume Button: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Locate the silver volume button on the side of the phone.
    • Use the precision tweezers to slide the volume button out of the groove.
    • When replacing the volume button align the flat side of the button to the silver edge of the display with the rounded edge facing the black frame.
结论
Nicole
于10/08/14注册
211 声望
创作了2篇指南
团队
USF Tampa, Team 9-4, Leahy Fall 2014 USF Tampa, Team 9-4, Leahy Fall 2014 的会员
USFT-LEAHY-F14S9G4
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 495
