跳转到主内容
JD Razor 2000 Front Wheel Replacement
你所需要的
  1. JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: 步骤 1 中的图像 1,3 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: 步骤 1 中的图像 2,3 JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: 步骤 1 中的图像 3,3
    • Orient the scooter so that the front wheel is facing you. Observe the right and left side of the wheel. Remember which is which throughout the guide.
    • Using an Allen wrench, unscrew the axle bolt slowly from the right side while applying a constant pressure with your hand on the left side of the bearing.
    • If the left side of the bolt turns while you unscrew the right side, you will need to use a second Allen wrench to prevent it from moving
    • If the bolt does not move at all, or moves very little, try applying a lubricant on as much of the screw as possible and try again in 5 minutes.
    • Carefully pull apart the bolt and bearing from either side of the wheel.
  2. JD Razor 2000 Front Wheel Replacement, Removing the Wheel: 步骤 2 中的图像 1,1
    • Grip the bottom of the wheel and gently slide it out.
结论
Kaylan Naicker
于10/14/14注册
255 声望
创作了2篇指南
团队
Cal Poly, Team 4-46, Amido Fall 2014 Cal Poly, Team 4-46, Amido Fall 2014 的会员
CPSU-AMIDO-F14S4G46
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 23
总计 938
