跳转到主内容
JD Razor 2000 Fastening Button on Handle Bar Replacement
你所需要的
  1. JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the String: 步骤 1 中的图像 1,3 JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the String: 步骤 1 中的图像 2,3 JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the String: 步骤 1 中的图像 3,3
    • Firmly hold the handle bar in place.
    • Grab with one hand the black removable tip of the handle bar and pull it out.
    • Pull out the end of the tied string through the removable tip.
  2. JD Razor 2000 Fastening Button on Handle Bar Replacement, Untying the Knot: 步骤 2 中的图像 1,2 JD Razor 2000 Fastening Button on Handle Bar Replacement, Untying the Knot: 步骤 2 中的图像 2,2
    • Untie the knot at the end of the string.
    • If you let go of the string while its in tension, it may recoil far into the other side of the handle bars. To avoid this, bring the end of the string inward towards the hollow section of the handle bar and then carefully let it go.
  3. JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the Handlebar: 步骤 3 中的图像 1,2 JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the Handlebar: 步骤 3 中的图像 2,2
    • Press down firmly on the golden fastening button located on the handle bar being replaced.
    • While still pressing down on the fastening button, slide the handle bar apart from the T Bar.
    • When re-installing the handlebar (after completion of the guide), you may need a pair of needle-nosed pliers to thread the string back through the handlebar.
  4. JD Razor 2000 Fastening Button on Handle Bar Replacement, Depressing the Button: 步骤 4 中的图像 1,2 JD Razor 2000 Fastening Button on Handle Bar Replacement, Depressing the Button: 步骤 4 中的图像 2,2
    • Press strongly down on the golden fastening button located on the loose handle bar.
  5. JD Razor 2000 Fastening Button on Handle Bar Replacement, Grasping the Button: 步骤 5 中的图像 1,2 JD Razor 2000 Fastening Button on Handle Bar Replacement, Grasping the Button: 步骤 5 中的图像 2,2
    • Tilt the opening of the handle towards you.
    • Reach in carefully with the small needle-nose pliers and firmly grab the golden fastening button.
  6. JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling out the Button: 步骤 6 中的图像 1,2 JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling out the Button: 步骤 6 中的图像 2,2
    • Once grasping the golden fastening button tightly with small needle-nosed pliers, carefully and slowly pull it out of the handle bar.
    • Do not pull out the fastening button rapidly. This may result in the button shooting across the room with great speed.
结论
另外一个人完成了本指南。
Kevin Church
于10/16/14注册
297 声望
创作了2篇指南
团队
Cal Poly, Team 4-46, Amido Fall 2014 Cal Poly, Team 4-46, Amido Fall 2014 的会员
CPSU-AMIDO-F14S4G46
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 862
